Your name: Suggestion headline: Add command /group to let them know more information how to join any group like /tag and other /swat /army Picture: Keep the picture in this
Importance of suggestion: 5/10 Why should it be accepted: Greetings to everyone, Who wants to join any group just type /group there'll understand everything and it'll be good and whoever spamming any leader/staff for Please give me rank 1 the command will useful for newbies and old players doesn't know how to apply groups, so the requirements other groups is " 1500 score and 150 hours/200hours"
Add even score + and + hours of play time to let them know about groups requirement in the command and check it out from requirements group there you will know more information about the groups
This is irrelevant to be honest and I bet if this gets implemented It would take a lot of work and time from the developers. There are lots of groups nowadays that are still active and each of them has different requirements in-order to join. Also we have group section on forums for a reason. It has always been like that since before and I prefer the way how it works currently.
Crazymix wrote :This is irrelevant to be honest and I bet if this gets implemented It would take a lot of work and time from the developers. There are lots of groups nowadays that are still active and each of them has different requirements in-order to join. Also we have group section on forums for a reason. It has always been like that since before and I prefer the way how it works currently.
Negative
We are know there's lots of groups, but he can use /group and "type name the group he want to know" just only
Good idea but it would be better if devs add a template which (ONLY Owner) can edit it. Refer the example below which (Leader) can edit the MOTD of their group.
Message of the day Note: The message should consist of 4-128 characters. Message will be updated upon server restart. You can add a color message from the colorpicker option below.
Negative
I don't think so, we just add the command /group and list of groups in /group add score hours of play time in the command /group whenever someone should join any group he'll type /group there will learn everything like /tag/swat/army if the command will take time why devs made /tag, that's all
Negative
/tag /swat /army are totally different from the one that you are suggesting, they are factions which everyone should know about. Group section on forum is enough for me in my opinion. And also each group has different rules so adding this one would be pointless as the player still needs to visit forum to check on the group rules and other information about the group.
TomaHawk wrote :Good idea but it would be better if devs add a template which (ONLY Owner) can edit it. Refer the example below which (Leader) can edit the MOTD of their group.
