Johnson wrote:YOU WANNA KNOW THE TRUTH? YOU CAN'T HANDLE THE TRUTH5Tamer wrote:MTA and SA-MP are very different,well MTA is more efficient than SA-MP,you don't need to lag shoot,NPC's are better,you can put skin mods/new effects and much more at MTA but there is one thing you are missing,the playerbase of ls-rcr is good at sa-mp,nobody can know if it would be good in MTA. Besides MTA and SA-MP uses two different languages to set up a gamemode,this means to make a mta server you need to learn everything from 0 and create a ls-rcr gamemode on mta. It's not just like "okay lets go move mta" and the other day you are on mta,doing this is alot of effort and also useless. MTA has a low playerbase and usually is not liked to be used,due the downloads,it takes long to login a server,the features are great thought,but it won't happen.Agreed
I don't believe Energ would put such a huge effort to make a second server on mta,which would just make us spend money for no reason. Also he needs to learn how to lua script (if he doesn't) and move everything to MTA you can even loose some of the features in sa-mp if you move mta. Besides,there are hackers,you are wrong.
Hackers can easily be avoided by complex systems in sa-mp but it's kinda hard to get it done..
killdahobo99 wrote:Johnson wrote:YOU WANNA KNOW THE TRUTH? YOU CAN'T HANDLE THE TRUTH5Tamer wrote:MTA and SA-MP are very different,well MTA is more efficient than SA-MP,you don't need to lag shoot,NPC's are better,you can put skin mods/new effects and much more at MTA but there is one thing you are missing,the playerbase of ls-rcr is good at sa-mp,nobody can know if it would be good in MTA. Besides MTA and SA-MP uses two different languages to set up a gamemode,this means to make a mta server you need to learn everything from 0 and create a ls-rcr gamemode on mta. It's not just like "okay lets go move mta" and the other day you are on mta,doing this is alot of effort and also useless. MTA has a low playerbase and usually is not liked to be used,due the downloads,it takes long to login a server,the features are great thought,but it won't happen.Agreed
Tamer wrote:MTA and SA-MP are very different,well MTA is more efficient than SA-MP,you don't need to lag shoot,NPC's are better,you can put skin mods/new effects and much more at MTA but there is one thing you are missing,the playerbase of ls-rcr is good at sa-mp,nobody can know if it would be good in MTA. Besides MTA and SA-MP uses two different languages to set up a gamemode,this means to make a mta server you need to learn everything from 0 and create a ls-rcr gamemode on mta. It's not just like "okay lets go move mta" and the other day you are on mta,doing this is alot of effort and also useless. MTA has a low playerbase and usually is not liked to be used,due the downloads,it takes long to login a server,the features are great thought,but it won't happen.omg DOCTOR. Sa-mp is here, RUN!
