BeaTen. wrote:Ingame name: [Lsrcr]BeatEn.Testing template isn't 'existent' but testers know which are the Skills to value in a test.
Rank: Rookie
Question: Where is the testing template? Is it hidden or anything else?
Dani6 wrote:BeaTen. wrote:Ingame name: [Lsrcr]BeatEn.Testing template isn't 'existent' but testers know which are the Skills to value in a test.
Rank: Rookie
If you refer to 'Thank you for applying for The Saints, you can get tested by...', it isn't 'existent' either, you can copy & paste a quote from another application & edit the username at the first sentence.
Viktor_Saiko wrote:Yes, you're right. For example -Dani6 wrote:BeaTen. wrote:Ingame name: [Lsrcr]BeatEn.Testing template isn't 'existent' but testers know which are the Skills to value in a test.
Rank: Rookie
AND change the player-names - some of the testers don't have a tag.
BeaTen. wrote:If i don't have a bad memory, he asked to use his username with Tag in the testing template, i'll ask him personally if there is any inconvenience.Viktor_Saiko wrote:Yes, you're right. For example -
AND change the player-names - some of the testers don't have a tag.It's meant to be without the tag.
- [Lsrcr]Triple[H]Daka
Dani6 wrote:Why would someone do that, he doesn't have the tag so his name is suppose to stay like that on the template.BeaTen. wrote:If i don't have a bad memory, he asked to use his username with Tag in the testing template, i'll ask him personally if there is any inconvenience.Viktor_Saiko wrote:Yes, you're right. For example -
[Lsrcr]Demon. wrote:Ingame name: [Lsrcr]Demon.As far as i know, you were inactive, NiNo posted on your behalf, now that you're back, the Memberlist has been updated.
Rank: Captain
Problem/Querie: This aint a problem but didn't know where to post it, edit my name on the member list, it says I'm inactive.
Dani6 wrote:As i've said, basing on my memory (which probably isn't good) he asked for that, obviously doesn't have sense but there might be reasons that the player could keep in secret to others, who knows.I asked dani do remove the tag even it was removed
Remember that ANY member with ANY rank can reply with the template & also you can correct it (removing the tag from T.Os, Correcting grammar...), will solve this as soon as possible.
