BoSS wrote:Only problem I see is that if someone resets it while one or more SWATs are about to drag a suspect then the suspects ends up in base then that can be an issue but can easily be solved by asking before reset. Anyways, +1.We always can add a rule to ask via /Sm if he can /swatfix or whatever will be the command.
Zoroark wrote:I've given people in game moneyHis life is fulfilled now
Kaosx234 wrote:And you should first wait 10 In-game seconds and if nobody says "don't reset" or whatever you must not, just my idea though.Only problem I see is that if someone resets it while one or more SWATs are about to drag a suspect then the suspects ends up in base then that can be an issue but can easily be solved by asking before reset. Anyways, +1.We always can add a rule to ask via /Sm if he can /swatfix or whatever will be the command.
