OsamaAbouelhassan wrote:In game name : [Lsrcr]Osama
Suggestion : Demotion instead of getting a kick after getting 3 warnings
Explanation :Receiving a rank demotion after getting 3 warnings instead of getting kicked from the team
Reason :Well, I know that the 3 warnings limit ensures that every member will avoid rule breaking but I'm also sure that all members are aware of the rules ... I mainly suggested this because most of the rules, almost all of them are broken due to accidents and not on purpose .. Therefore, the result of commuting 3 rule breaks should be less strict and it will be fair enough as well.Answer:
Compliance with the rules is a very important duty. Members who violate the rules will be punished. I always encourage members to learn all the rules in order to avoid any misunderstanding that might occur intentionally or unintentionally. This will be not added.
Suggestion : Adding a sixth rule for the conditions that disallow dragging
Explanation :Do not drag in the small bank located in pershing square .. It will be the only exception regarding dragging in interiors as the drag doesn't successfully take place .. This happened to me when a member failed to drag me in it and [Lsrcr]Tamer informed me as well to avoid dragging in it
Reason :Drag fails = Score boosting, simply.
