Blizzard wrote:trashLumix wrote:Knew someone would do this. Anyway:i found my cpu in my cereals, where did you get yours?
Processor dual king core 0.9 GHz
Graphic nvidia intel black 63662
1 GB ram
Hard Drive 25 GB
No monitor
Speakers found in trash
Keyboard borrowed from cousin
Mouse old 5 years
No headphones
Guys, could I run GTA V or rainbow six siege?
Dimitrije. wrote:As we use pretty the same gpu are you getting some over heating issues?My PC specs:
CPU:Intel Core i5-4460 @ 3.4GHz (OC'd)RAM:1 stick of DDR3 Kingston 8GB memory 1600MHzGPU:MSI GTX 750 Ti 2GB OC version (1 cooler)MOBO:ASUS H81M-RHDD:TOSHIBA 1TB 3.5'' SATA III 32MB 7.200rpm DT01ACA100OS:Windows 7 - 64bit Service Pack 1MONITOR:ACER V226HQL: 21.5" (55cm) 5ms TN panel - 1920x1080 @ 60Hz
RAIFMS wrote:viewtopic.php?f=612&t=75268Dimitrije. wrote:As we use pretty the same gpu are you getting some over heating issues?My PC specs:
RAIFMS wrote:TBH, no.. It actually all depends of what usage is my GPU cooler speed. I use MSI Afterburner for adjusting GPU clocks and FAN SPEED (cooler). When I boot up my PC, I set it from 30% (which is by default) to 50% and it usually doesn't reach some EXTREMLY HIGH temperature such as 70°C. Never gone above 66°C.Dimitrije. wrote:As we use pretty the same gpu are you getting some over heating issues?My PC specs:
Dimitrije. wrote:Lask week i was playing csgo for like 3 4 hours it got up to 85°cRAIFMS wrote:TBH, no.. It actually all depends of what usage is my GPU cooler speed. I use MSI Afterburner for adjusting GPU clocks and FAN SPEED (cooler). When I boot up my PC, I set it from 30% (which is by default) to 50% and it usually doesn't reach some EXTREMLY HIGH temperature such as 70°C. Never gone above 66°C.Dimitrije. wrote:As we use pretty the same gpu are you getting some over heating issues?My PC specs:
