Naruk wrote:Hey Clit, I have a modification for the first suggestion.When cuffed you can only jog, not sprint.
If we were to remove the freezing effect of cuffing, we probably also should either make people able to "run" or just "walk", and if we were to enable cuffed players to "run", like spamming space, then removing the "invulnerable" effect should be also removed. But idk, if we only enable them to "walk", can't press space, then most likely we're going to retain the "invulnerability".
[Lsrcr]Robin wrote:Not really, the invulnerability effect was because we had to prevent the cuff killing abuse. Don't really know how it runs if ever the suggestion gets accepted. Isn't itNaruk wrote:Hey Clit, I have a modification for the first suggestion.When cuffed you can only jog, not sprint.
The invulnerable effect is because of the freezing also, so that's removed automatically.
Hawk wrote:I think that both option #1 and option #3 are useful. Tazing time is slower, and running while cuffed is good because they can get tazed again? An LEO has to go to more processes to arrest a criminal; therefore it would be more challenging for the cop and the criminal would have more chance to escape. I think balance would be possible here!
CXdur wrote:Do you guys still believe that changes are necessary? We do not want to decrease the jail time as it would devalue jail cards, but do you still think it's too unbalanced? I personally feel like it's a lot more balanced in most cases now and chases last a lot longer, you have more chances at escaping and I don't see them as overpowered as they were. I want your opinions though and more suggestions are appreciated if you have something good.Run while cuffed would do nicely since in real life people do try to run while cuffed.
