You are banned from the server (bug)
Bug reports that are very old and may or may not still be valid with the current state of the server.
11 posts Page 2 of 2
Post by Astrl » September 30, 2016, 7:35 pm
69. wrote:
everyone's timing out every 10-15 mins
This was a separate issue, that has been fixed.
Also, For the "You are banned from the server" that is nothing we can fix - like I previously said here:
Does it show up with the "You are banned from this server." string?
That's a SA-MP sided bug and isn't our fault / problem with the server, It's caused by high ping / unstable connections to the server.
It also happens when you restart some SA-MP servers, it's more annoying than anything else, just /q and rejoin the server and it's sorted usually :P Sometimes you'll need to close your SA-MP also.
If this happens persistently please try and sort your internet stability out and check for packet loss, this may cause timeouts and stuff.
Topic locked as this is not a bug that's related to Lsrcr's SA-MP server, this is a bug that is due to your own connection.
Return to “Stale Reports”
