Hacker Class - Share your ideas
46 posts Page 2 of 5
Bobbi
Bobbi
Post by Bobbi » January 23, 2017, 3:20 pm
Sounds amazing waiting for it. :) :)
Rally3
[2F2F]jimmyfallon
Post by Rally3 » January 23, 2017, 3:30 pm
nitins idea is pretty good tbh
Nyut
[Lsrcr]Nyut
Post by Nyut » January 23, 2017, 3:39 pm
Ok so i got suggestion that i discussed with Stephen. I'm going to explain them here. If there's a flaw or something, just tell me.
Suggestion 1: Hacker needs to buy a Phone/a Laptop to hack.
So this is a nice one, if you spawn as a Hacker class, you will need to buy a Phone or a Laptop at 24/7 stores. For hacking small things like ATMs, you will require a Phone. For Alca, you will need a Laptop for it, since logically a big thing to mess up with literally needs a more reliable tools. For me, ideal prize for a Phone is between 500-1500 dollars. Whilst for Laptop is 2500-3500 dollars.
Suggestion 2: Hacker can override cars system around him that a LEO drives or contains a LEO for 5-10 seconds
I don't think LEO's will be happy with this, but it's worth mentioning. So, a Hacker can do this if he buys a Phone and type a certain command to disable/override cars around him (Approximately around 2-4 meters) that contains LEO or belongs to LEO or driven by LEO. Since this is too OP and not many people will like it, i'd suggest that you can add cooling time/timer for each use by 5-10 minutes, 15 minutes max.
Suggestion 3: Robbing Bank by using Special Laptop that can be bought from Black Market
Yes, so here comes the final one. You can rob Bank by using a Special Laptop that you can buy from Black Market for a higher price, which, i still can't decide the price is. So of course, you don't need to go to Claude. By typing a command, a Hacker can hack into the bank system and opened BOTH vault doors at the same time. Of course, to make this not too OP in the first place, there's a timer for the system to be hacked.
Suggestion 4: A Hacker can clear, or, at least reduce his wanted level.
Another suggestion that might be hated by LEOs. A hacker, of course, can hack into the PD system and hack his own wanted level. This depends on luck and MUST BE BELOW wanted level 10. Hacker can type a certain CMD to lower his wanted level and try to escape. Since this can become abuseable, i suggest adding a cooling time for 20 minutes or more. Needs a phone to proceed with this.
Suggestion 5: Hacker can 'Hide' his presence.
Just like S.W.A.T, Hacker can "Hide" himself from the Radar and Map for a certain amount of time, which i suggest being the same as S.W.A.T or lower. Hacker needs a Tool that i mentioned to hide his presence completely from the Map for a certain amount of time, depends on the Tool he chose. If he uses phone, he got less time than when he used Special Laptop from Black Market. Add a cooling time after one use for 10-20 minutes.
A correction or criticism to these suggestions i gave will be very much appreciated. Thanks for reading.
Post by Robin » January 23, 2017, 4:10 pm
Disabeling shop alarms (dispatch radio for LEOs) for certain shops in a pre-defined range around the place where the hack took place for X minutes.
Like, I can disable all shop alarms in a range of 100 meters once I did the hack for 2 minutes.
Zoroark
Zoroark
Post by Zoroark » January 23, 2017, 4:58 pm
Nyut wrote:
I feel if a class is going to buy this phone or laptop from anywhere it'd be the black market. It doesn't make sense to be in a convenient store LOL. Like all items go in the black market not just the special one. Just put the hacker class purchase area in that weird balcony/hallway thing near that big military base like door. The hacker class purchase areas isn't affected but the normal purchase shit and get wanted thing due to the items being expensive as fuck.
Phone: 10k
Laptop 20k
Special phone 45k
Special laptop: 85k
The special phone can hide the locations and rob shit while the normal phone can only hit ATMs vending machines along with the bus terminal
Laptop can do all normal stores
Special laptop can hit casinos the bank and areas where a pipe bomb is required
Each item lasts for only 40 small robs 30 regular robs and 5 huge robs. (Ex you can only rob from the bank city hall and Casinos 5 times. Then the laptop in theory gets destroyed so it isn't traced by police)
Reduceing wanted level is a CMD that you should pay for. If you are most wanted that's the only time it can't be used and the reason is you are too well known by police and if they try anything the company that causes the wanted level to reduce will get caught forging paperwork (we gonna say the shadow company is behind the black market and this CMD)
Yellow wanted: 1000$
Orange 5000$
Red: 25000$
20min cool down is fine but personally I'd have it at 40min cool down cause I would rather use it when red but have a longer cool down so it isn't too op. (Also being a hacker means you can't /rob or /rape people if this stuff is implemented. Cause hackers are no life virgins anyways LOL)
mo5rb
Mo5rB
Post by mo5rb » January 23, 2017, 5:16 pm
+1
Nyut
[Lsrcr]Nyut
Post by Nyut » January 23, 2017, 5:18 pm
Zoroark wrote:
Nyut wrote:
This.
Jawzom
Jawzom
Post by Jawzom » January 23, 2017, 6:06 pm
@GalaxyGeri
Why would you want to put anything at 10k score, I don't even have half of that and I've played here for a while.
Geri
Geri
Post by Geri » January 23, 2017, 6:43 pm
Jawzom wrote:
@GalaxyGeri
It was a mistake by me, i meant 1k score, sorry for that.
glgy geri
Sonit
Sonnet
Post by Sonit » January 25, 2017, 6:02 am
I'll like to suggest one simple thing. Black market is located inside the jefferson tunnel. Now we gotta go to Black market from where we spawn, then we go to ATM or other robable store & rob it. People are tooo lazy to do all this literally.
- I prefer either make 2-3 more branches of Black market with-in Los Santos because jefferson tunnel is a bit far away + no car spawn nearby it. It would be great if somewhat of a cave type structure of Black market can be created somewhere at Ocean docks side & Market.
- Or make these items (laptop, phone, etc) available at 24/7 or other stores.
[Lsrcr]Sonnet: TOP 7TH Most Active Player, Anime Brigade member,Blackouts 2 Consigliere, Supporter, [Lsrcr] Tagged, Ex-Army, S.W.A.T. SGT, Absynth's Crew, LSPD United Officer, Top 19th Robber, top 15th Hotdog seller,
Activity: Ingame: Very High.
Forum: Very High.
TeamSpeak: Medium.
