Add ATM robbable once again !
19 posts Page 2 of 2
Kawish
[Lsrcr]Kawish
Game Moderator
Event Host Supporter SWAT VIP Blackmarket VIP
Post by Kawish » December 5, 2017, 10:16 pm
Mr.Nightmare wrote:
+1 but you'd need a screwdriver to do it.
Demon.
Demon
Post by Demon. » December 6, 2017, 5:36 pm
bring it back like the way it was, no need to change anything
Ritz
[Lsrcr]Ritz
Post by Ritz » December 7, 2017, 2:10 am
There must be a reason for them to remove it before.I think have it a little bit changed will be good.
jilla123
Jilla
Post by jilla123 » December 9, 2017, 1:56 am
Don't think it's needed.As a guy suggested to add more stores in Los Santos and other places this will not be necessary.So,negative.
Zoroark
Zoroark
Post by Zoroark » December 9, 2017, 8:32 am
Make it a hacker class exclusive where you have to buy a bug for the atm and hypothetically you are stealing someone’s card info (Whenever the hacker class even comes out.)
But in reality it would be a simple plant and rob like the pipe bomb but implemented differently. Ex use /bugatm then when planted you have to run away and hide for a few seconds to get your money. (You wouldn’t get a wanted level till after the rob simply because you’d have to run a distance away or all you get is a wanted level)
The bug would have to be bought at the black market though and can only be used in the hacker class. (VIP package would be able to spawn one)
I feel it’d be a great addition to that but that’s just me.
Also kind of want the hacker class to be implemented already.
Ritz
[Lsrcr]Ritz
Post by Ritz » December 9, 2017, 11:50 am
This one will be good,but need much works for developers I guess.But will be considered I guess from senoir admin.
RedstarS
Post by RedstarS » December 9, 2017, 2:15 pm
ok +1
Demon.
Demon
Post by Demon. » December 9, 2017, 5:01 pm
nop, they removed it cause they were going to add the hacker class and bring it back
StephenKelly
Stephen
Post by StephenKelly » December 12, 2017, 7:01 pm
We already accepted or came up with a similar idea a while back, no idea if it's being developed at the moment though.
Thanks for the suggestion anyway
Return to “Accepted”
