So you said reality,
Let's consider everything in reality.
Remove /ar command
In real do you arrest like this ? The suspect went directly to jail?
Cuff range: In real only when the suspect is near it can be cuffed. But here cuff range is more and even more in swat.
In real do you use army vehicles like Hydra,tank, chopper etc in real city? And blow up roads?
If you start talking about reality then there are much more cases which are not real at any context.
Suggestion is just nothing useful and it will reduce the criminal activity which is already dead.
We don't believe this should be implemented, and it looks like most community members agree.
This is a semi-roleplay server, there are many things that are not even a bit close to reality. In reality you can actually lock your vehicle, so why would we not allow criminals to do this? As for LEOs being able to break the doors/windows in real life, criminals can also do it.
We believe it's fine the way it is now and it has never been an issue.
Suggestion has been dismissed, but thanks for it nonetheless!
