Santiago wrote:It turned out great! I'm glad I could helpHere is a tutorial for this jump on Blackouts base using grenades, this one is more obvious and absolutely easier...
ackman wrote:number of times you failed at making this jump?Firstly when I discovered it is possible, I did it twice without failing.
Diplomatic. wrote:Nice, keep it up! <3ackman wrote:number of times you failed at making this jump?Firstly when I discovered it is possible, I did it twice without failing.
Then I failed a lot while trying to do it again after that to be honest, but after I and Santiago worked on it in a virtual world for a bit, we totally got it and we fully knew how to do it correctly. Hence we used to do it repeatedly with 0 failure attempts
ackman wrote:Chilling in army skin okDiplomatic. wrote:Nice, keep it up! <3ackman wrote:number of times you failed at making this jump?Firstly when I discovered it is possible, I did it twice without failing.
ackman wrote:Nice one but this should be fixed in Blackouts group next updates.hahahahahah
Already in a mind to block this because of roadblock and stuff
