Triple[H]DaKa wrote:I'm sorry for the issue, i don't have a good memory then, once again my apologies about the issue.Dani6 wrote:As i've said, basing on my memory (which probably isn't good) he asked for that, obviously doesn't have sense but there might be reasons that the player could keep in secret to others, who knows.I asked dani do remove the tag even it was removed
Remember that ANY member with ANY rank can reply with the template & also you can correct it (removing the tag from T.Os, Correcting grammar...), will solve this as soon as possible.
hanishah62 wrote:Ingame name: CrimNaleRYour rank is respectively called "rookie" not rokie.
Rank: Saints rokie
Suggestions: saints member should get free weapons without money from weapon wall althought if its also possible with drygs thahts also good but guns should be free . that all my suggestion
Viktor_Saiko wrote:Vic's right, people are joining black tigers just for free weapons.hanishah62 wrote:Ingame name: CrimNaleRYour rank is respectively called "rookie" not rokie.
Rank: Saints rokie
About the suggestion - no, weapons and drugs are going to be kept on the payroll for a while, to prevent players who only want free things from joining the Saints. We'll probably add an ATM to the base, so when you're out of money, you can withdraw some.
Viktor_Saiko wrote:As VIC already said, this suggestion isn't approved.hanishah62 wrote:Ingame name: CrimNaleRYour rank is respectively called "rookie" not rokie.
Rank: Saints rokie
Elite wrote:Ingame name: [Lsrcr]EliTeWe are really sorry for the inconvenience, your name has been added to the memberlist, if i don't have a bad memory, you've been a Saints member for a couple of months.
Rank: Rookie
Question: Why is my name not on the Memberlist? I'm pretty sure I got accepted a while ago..
