Dynamic Weather
27 posts Page 3 of 3
Raif
Raif
Post by Raif » July 4, 2016, 7:43 pm
aky wrote:
Some players have had the problem with that. It's kinda lagging but I prefer making a command /toggledownfall(for the rain, and such other weather).
I agree with this. +1
If like this ^ +1
Tagged Member - Retired - That's all you need to know.
Cyanide
Cyanide
Post by Cyanide » July 8, 2016, 11:09 pm
Listen hawk, the weather in leave as same as the normal weather in real life a and I like it and you know so much players groom Egypt same me have a bad comp and it will make the server lag
@sky if you need command too change weather its so bad and you will make this player will be different for players its now good all the players have the same weather, no lag and the normally weather irl
Hawk
Hawk
Post by Hawk » July 10, 2016, 8:56 am
Players should indeed have the same type of weather, however I really think it is boring having the sunny 24/7 weather. Server will not lag at all, because FPS is only affected from the client-side. Of course not everyone has a good computer; therefore in that case there should be a selection of weathers which are not so heavy for bad computers.
Regarding the usage of commands about toggling a weather, I don't think it would be balanced as players should have the same weather during combat and RP.
AllCopsAreBastards0.
Post by AllCopsAreBastards0. » July 10, 2016, 9:00 am
GuitarJohn wrote:
Good point.
Bobbi
Bobbi
Post by Bobbi » July 10, 2016, 11:56 am
-1 it makes the server laggy. my Pc already sucks :( i'm playing in 40 fps :(
P.A
SWAT
Post by P.A » July 10, 2016, 3:10 pm
Read others reason then you can vote. They said you can use /toggleweather if you didnt want to use it.
Shady
Shady_Haru
Post by Shady » August 30, 2016, 3:06 pm
This was added - viewtopic.php?f=7&t=75631
Return to “Accepted”
