Adding AFK zone
If you have a suggestion related to our server & gamemode, you can share it here.
40 posts Page 4 of 4
Milyn
Milyn
Blackmarket VIP
Post by Milyn » June 15, 2019, 10:35 am
Mr.DollarMan wrote:
If it's possible to add an additional column in "TAB" list which will show which player is AFK and which is not then it will make things easy for everyone.
For Example:
Or you can add an additional informative sentence when someone locates a player.
/loc 1
Notification: Location: Idlewood. Status: AFK.
If there is a cmd like /afk that displays the list like this it will be more simplified instead of adding in Tab list
Post by Robin » June 15, 2019, 10:58 am
For Example:
/loc 1
That’s not possible.
Mr.DollarMan
Mr.DollarMan
Post by Mr.DollarMan » June 15, 2019, 11:16 am
It's easy to press tab and see who's AFK and who's not rather than typing a command. However Robin said it's not possible.
The "Tab" thing couldn't be implemented but the /loc command idea can work.
Signature Credit: King_Mahathir.
Thursday
[Lsrcr]SlambeiY
Post by Thursday » June 16, 2019, 2:51 pm
For Example:
/loc 1
I tested it is worked when you afk,press esc as well
+1
Credits: KikoLolo
Mastro
[Lsrcr]Mastro
Post by Mastro » June 24, 2019, 12:58 pm
The idea is not bad but I am not quite sure how important/needed it is as many have mentioned. You can always PM them and see, or just locate them. If the location remains the same they are most likely away from keyboard.
This might be implemented, however other similar afk checks will definitely be looked into (e.g players not being able to kidnap afk players anymore etc).
Balsa
[Lsrcr]Balsa
Post by Balsa » June 24, 2019, 2:56 pm
That was mine suggestion mate and it is still "PENDING" but i understand you
Balsa
[Lsrcr]Balsa
Post by Balsa » June 24, 2019, 3:03 pm
I mean before forum got update
Milyn
Milyn
Blackmarket VIP
Post by Milyn » June 24, 2019, 3:07 pm
Pm does not work when the player switches his pms off also loc might be same as the areas are quite big
Mastro
[Lsrcr]Mastro
Post by Mastro » June 24, 2019, 5:11 pm
I agree with this, still it's definitely low priority but will definitely be looked into sooner or later. For now we need to work on other things.
Mastro
[Lsrcr]Mastro
Post by Mastro » July 21, 2019, 4:43 am
Mastro wrote:
However other similar afk checks will definitely be looked into (e.g players not being able to kidnap afk players anymore etc).
This has now been implemented. Players can no longer kidnap players who are AFK. Will be pushed along with other updates.
Return to “Server Suggestions”
