KARTHIK_RKZ wrote:And that, my dear, isn't truth. I managed to kill driver, and someone in the car, Idon't remember kilking someone on it. As Armaros said, driver, and passengers in the car get instantly killed, however, people on the car have a chance of escape, because the bomb can only kill you if it is deployed right next to you, and we practice to deploy it in front of the car, to imobilize and kill the driver, so that the car itself can explode and to the double surrounding damage. People on the car are usually scattered around when they see swat approaching, so the guys on the car can really avoid the bomb in general, and they usually get little to no damage from the bomb.Armaros wrote:Nah from my experience car surfing players dont get instantly killed only those inside car maybe.
They'll. Last day we faced the same thing. Me, Raskit,Spicy and Shaco was on the car and nikola bombed us and we died instantly.
Shaco wrote: Shit is too OP as it is right now. No chance for criminals to run away or defend themselves + SWAT doesn't even get damaged from it.Criminals can easily run away. The bomb damages only those INSIDE the car, and hence majority of the time the cophunters can escape. Also, there are Bomb Jammers available.
shiny wrote:Yeah its too op and the criminals cannot escape from it, Its unfair.Refer to Answer 1.
KARTHIK_RKZ wrote:Yes, It is too op.Refer to Answer 1.
Rally3 wrote:timer seems reasonable since swats can just jump out of the car and insta detonate it.Considering that adding a timer to such an object basically renders it unusable. You're literally adding a loud ass tick tock to a huge ass bomb, everyone would then know there's a SWAT bomb nearby and the entire point of stealth is taken away.
Shaco wrote:Keep in mind that not everyone can buy the bomb jammer / not everyone can enter the blackmarket, You need a certain score.Your logic works the other way too, not everyone has the SWAT bomb barring 16 members of the community, compared to the
Shaco wrote: + it's difficult to type /jamswatbomb in 0.5 seconds.I see no issue to change the /jamswatbomb command if the length is an issue.
Shaco wrote: To add up with all of this,it even make players timeout. May sound funny but it happened to Raskit,Spicy and I in the past few days (and today)If the reason to remove it is that it makes players timeout, either replace it with a similar weapon entirely or fix the error.
shiny wrote:Also swats have /smh also thats not fair, /smh + swat bomb = rip suspects!Check out the Black Market, the Army Section, hell even the Terrorists base. If you scream that out of EVERYTHING present on the server, /smh is the most dangerous, God save you.
Nikola_123 wrote:KARTHIK_RKZ wrote:And that, my dear, isn't truth. I managed to kill driver, and someone in the car, Idon't remember kilking someone on it. As Armaros said, driver, and passengers in the car get instantly killed, however, people on the car have a chance of escape, because the bomb can only kill you if it is deployed right next to you, and we practice to deploy it in front of the car, to imobilize and kill the driver, so that the car itself can explode and to the double surrounding damage. People on the car are usually scattered around when they see swat approaching, so the guys on the car can really avoid the bomb in general, and they usually get little to no damage from the bomb.Armaros wrote:Nah from my experience car surfing players dont get instantly killed only those inside car maybe.
notanadmin wrote:Criminals can easily run away. The bomb damages only those INSIDE the car, and hence majority of the time the cophunters can escape. Also, there are Bomb Jammers available.I was on the car and I still died.
Shaco wrote:SWAT Bomb is really buggy as well. Sometimes the detonator doesn't work and you need to type /detonator as well. Sometimes the criminals are really laggy. It could be unfair for you, but i really have failed so many times catching a biker with a swat bomb, even when he was really close to it, because of his high ping. It is almost impossible to stop a biker with a roadblock, due to their ping. They must have the ping at least 60 to block them with roadblock, and its the same on the car. If you have a high ping, you wont be damaged a lot. It is really useful, but only to the ones which know how to use it. And yeah, i still bring up the army tank for the defensive reason. As long as army got a really defensive tank, we should at least have the bomb, to knock the criminals away. Remember, that unlike army, we can only cuff the suspect and make sure the car is there to drag (only 1 suspect). So, if we cuff all the cophunt, then there would be no way to arrest them all, because they could break the cuffs. As i said, swat bomb is really useful, only when you know how to use it. I do not think there would be any chance to kill you guys without the swat bomb. And if you are requesting this, then there would be no challenge for you. You can copy /jamswatbomb command and CTRL + V it when you want to in less then 0.5 seconds, so there is a way to dodge it. Or you can just move to the other way to again dodge it.notanadmin wrote:Criminals can easily run away. The bomb damages only those INSIDE the car, and hence majority of the time the cophunters can escape. Also, there are Bomb Jammers available.I was on the car and I still died.
I don't know why some of you are comparing it to the army tank. Army has every tool to eliminate wanteds because they are the deadly force for a reason. Without the rank,hydra and all the fancy vehicles,army would be just like regular cops. First of all army needs to /su and wait 5 seconds and second of all they are the deadly force for a reason. Not to mention that it's slow too. I knew you guys would bring up the army tank and that's why i suggested adding a timer or the /su command before deploying the SWAT bomb or at least SWAT members get damaged by it too.
When I spoke to CXdur about it yeterday,he told me to try it myself and I did. Had no problem killing with it because it is easy. When i was a SWAT member back in the day,we used to have a command (forgot what it was,maybe /prepswatbomb i dunno) and we had to type it before deploying it. Now all you need to do is exit or jump off the vehicle with the detonator and double click it.
Just yesterday,when we prepared everything and got wanted,here comes this SWAT member jumping off the roof of their vehicle and killing 4 of us instantly. All i saw was just an explosion,not even an animation of the SWAT planting the bomb. Criminals already have lot on their plate; they have to /takedrugs,/stun and /sh to pre-type,doubt that someone can type /jamswatbomb in a matter of a second aswell.
Just for the record,i didn't ask for it to be removed. It just needs to be altered so it'll be fair for criminals.
And /jamswatbomb will be shortened to /jsb (afaik)
Shaco wrote:It Would be nice if they change /jamswatbomb to /jsbnotanadmin wrote:Criminals can easily run away. The bomb damages only those INSIDE the car, and hence majority of the time the cophunters can escape. Also, there are Bomb Jammers available.I was on the car and I still died.
Just yesterday,when we prepared everything and got wanted,here comes this SWAT member jumping off the roof of their vehicle and killing 4 of us instantly. All i saw was just an explosion and my dead body (lul),not even an animation of the SWAT planting the bomb. Criminals already have lot on their plate; they have to /takedrugs,/stun and /sh to pre-type,doubt that someone can type /jamswatbomb in a matter of a second aswell.
Shaco wrote:I don't want to come off as offensive, sorry if I sounded rudenotanadmin wrote:Criminals can easily run away. The bomb damages only those INSIDE the car, and hence majority of the time the cophunters can escape. Also, there are Bomb Jammers available.I was on the car and I still died.
