S.W.A.T. || How To Apply
Are you interested in joining the S.W.A.T. team? Post your application here!
1 post Page 1 of 1
S.W.A.T.
s.w.a.t.
Post by S.W.A.T. » September 19, 2013, 7:54 pm
How To Apply #1: Read and Understand the S.W.A.T. Rules, FAQ and Rules for Applicants
Rules for Applicants:
1. Before posting an application, you must read and understand the S.W.A.T. Rules. You must also read the Frequently Asked Questions (FAQ) for S.W.A.T..
2. Make sure you have at least 500 in-game score and 200 hours of activity (playtime). You can check your score by pressing "TAB" in-game, while your playtime can be viewed through the UCP at http://www.ls-rcr.com/ucp/ or by visiting your public profile at http://www.ls-rcr.com/user/add_your_name_here. If you do not meet these requirements, your application will be automatically denied.
3. Make sure you have a decent status as a Cop. We expect applicants to have a good Taze and Arrest level that outweighs their Rob and Rape levels. This helps us determine that you are active as Law Enforcement rather than as a Criminal.
4. Make sure you are well respected within the server community. A good reputation increases your chances of receiving positive votes on your application.
5. You must follow the application format provided below.
6. You may not ask S.W.A.T. members to review or vote on your application. This also applies to the S.W.A.T. High Command.
7. Do not spam your application. This includes unnecessary comments, chatting, or any other irrelevant replies.
8. You must wait until your re-application period has expired before applying again.
- If you were denied from Army, you must wait 1 week before applying for S.W.A.T. (If the Army General gives you a different waiting period, it only applies to Army.)
- If you were denied from S.W.A.T., you must wait for the period specified by the S.W.A.T. High Command before submitting another application.
9. You may not use a second account to bypass your waiting period.
10. You may not have an active Army and S.W.A.T. application at the same time.
11. You may not be a member of Army and S.W.A.T. at the same time on different accounts.
12. You may not be a S.W.A.T. member on more than one account.
13. If you previously applied for S.W.A.T. on another account and are now applying from a different one, you must inform the S.W.A.T. High Command. Failure to do so may result in a blacklist.
14. All S.W.A.T. times are based on GMT +2. Any waiting period given by the S.W.A.T. High Command is also based on GMT +2, so make sure to convert it to your local time if necessary. Reasonable tolerance applies.
15. If a Warrant Officer asks you to take your test, you may not refuse under the excuse, "I want to be tested by another tester." All Warrant Officers follow the same testing procedure and evaluation standards. Please note that "I'm not ready" is not a valid excuse. You are expected to be ready when you submit your application.
16. If you were banned while your application was active, your re-application period (7 days, unless stated otherwise) will begin from the day your ban is lifted.
17. Copying or modifying another applicant's reason is strictly forbidden. Failure to comply will result in your application being closed.
18. Your application reason is one of the most important parts of your application. We expect you to put genuine effort into explaining why you want to join S.W.A.T. Your reason must be original, unique, and written in your own words.
19. Use only original screenshots. Do not crop, edit, or modify them in any way.
#2: Making Your Application
The title of your application must be:
S.W.A.T. Application: [In-Game Name Goes Here]
(Example: S.W.A.T. Application: [Lsrcr]CresP)
Use the following format for your application:
Code: Select all
[quote][center][img]https://i.ibb.co/B2VBbqX/swatapplications.png[/img][/center]
[hr][/hr]
[legendary=#00FFFF,white,S.W.A.T. Application: In-game name]
[b]In-Game Name:[/b] Your In-Game Name
[b]Score:[/b] Your In-Game Score
[b]Country & Timezone (GMT):[/b]
[b]Website Profile:[/b] Your public website profile: https://ls-rcr.com/user/name
[b]Proof of Stats & Activity:[/b] Take a screenshot of your statistics from the UCP with your in-game name visible, then upload it to [url]http://www.imgur.com/[/url]
[b]Reason:[/b] Explain why you want to become a S.W.A.T. member. Your reason should be genuine, unique, and written in your own words.
[/legendary]
[/quote]
Failure to follow this format will result in your application being automatically denied. Make sure your topic title is correct, as an incorrect title may also result in an automatic denial.
Once your application is ready, post it in the Applications forum.
#3: Application Summary & Getting Tested
After submitting your application, S.W.A.T. members will review it and cast their votes. Votes can be positive, neutral, or negative.
Once your application has been verified, a Warrant Officer will post the testing information along with a list of the current recruiters. You may then contact any available Warrant Officer in-game or on Discord to request your test. If a Warrant Officer is unavailable or unable to test you at that time, please be patient and ask again later.
After your test has been completed, the Warrant Officer will post your test results on your application. Finally, a member of the S.W.A.T. High Command will review your application and make the final decision (accepted or denied).
Please note that asking the S.W.A.T. High Command to review or accept your application may result in consequences.
1 post Page 1 of 1
Return to “S.W.A.T. || Applications”
Users browsing this forum: No registered users and 0 guests
