Alcatraz Bug
Bug reports that are very old and may or may not still be valid with the current state of the server.
soomro56
soomro567
Post by soomro56 » September 9, 2018, 10:45 am
Where does the bug appear: Server
When did the bug appear: Alcatraz
Describe the bug: whenever i release from alca i always fall in water always.so please as soon as possible solve this problem thank you.
Mastro
[Lsrcr]Mastro
Post by Mastro » September 9, 2018, 12:22 pm
It's most likely because of your high ping. Objects don't load fast enough, hence why you fall under the map. I have never fallen under the map due to my low ping.
I suggest you press ESC right after leaving Alcatraz.
Return to “Stale Reports”
Users browsing this forum: No registered users and 0 guests
