Richano wrote:Should REALLY put that in the command list. Never knew it existed. I'm a moron, ignore me.Karu_Tepes wrote:Have you tried /remove?Richano wrote:I've pushed a fix and it should be on main soon (along with all other attachment command fixes). I'll leave this bug report open if it still occurs.Came to report a bug, but as you said attachments, I'll put it here...
Thanks for reporting!
You can only use /hats and /glasses once. If you do /hats 3 you cant remove it and cannot use /hats 5 to change hats, and the same occurs with /glasses as well. Not sure if that was fixed, but I'm bringing it up as an amendment.
Karu_Tepes wrote:I'll add a message on usage which says that you can remove this item by using /remove (itemname). Thanks for mentioning this though.Richano wrote:Should REALLY put that in the command list. Never knew it existed. I'm a moron, ignore me.Karu_Tepes wrote:Have you tried /remove?
