Balsa wrote:I don't think that this is a bug as this happened to me a lot before. Just don't be lazy and type /parrot again that's all. This should be a suggestion not a reportI’ve talked about this to Richano earlier and he told me to report it up here.
dev3r3r wrote:Deve - developers. Devs =Developers nothing is wrong with bothBear wrote:I've experienced this as well whenever I use swat skin, and I've talked to Immortal about it. And he said that deve are doing a action on it.Yes, devs HAHAHAHA
Tamer wrote:Helping players is not ass licking, this is literally being helpful
Richano wrote:I've pushed a fix and it should be on main soon (along with all other attachment command fixes). I'll leave this bug report open if it still occurs.Came to report a bug, but as you said attachments, I'll put it here...
Thanks for reporting!
Karu_Tepes wrote:Have you tried /remove?Richano wrote:I've pushed a fix and it should be on main soon (along with all other attachment command fixes). I'll leave this bug report open if it still occurs.Came to report a bug, but as you said attachments, I'll put it here...
You can only use /hats and /glasses once. If you do /hats 3 you cant remove it and cannot use /hats 5 to change hats, and the same occurs with /glasses as well. Not sure if that was fixed, but I'm bringing it up as an amendment.
