OMGHost wrote:Dont listen to him, He is trying to mess up your System.ker wrote:i had same problem and i deleted system32, works perfect now <3 <3What u mean system32
Jaker wrote:But yeah, please avoid doing so since it'll mess your system up.OMGHost wrote:He meant for you to go to Local Disk C, then Windows and delete the "system32" folder.ker wrote:i had same problem and i deleted system32, works perfect now <3 <3What u mean system32
Stormocide wrote:Well I cannot find Gta_sa.set in there.The only thing there is Gallery,User Tracks and SAMP and USERDATA.DATOMGHost wrote:Dont listen to him, He is trying to mess up your System.ker wrote:i had same problem and i deleted system32, works perfect now <3 <3What u mean system32
OT:
Go to Your PC > Documents > GTA San Andreas User Files > Find Gta_sa.set and Delete it. Then Open up Samp.exe and then try to Connect. If successful you should be good to go and all you have to do is just do your settings again (Like your Mouse sens, Resolution, Brightness etc)
If it still doesn't work, Please reply back.
-Storm
OMGHost wrote:Go to folder and search option.Click the View tab, Tick the Show hidden files and folders and then try again.Stormocide wrote:Well I cannot find Gta_sa.set in there.The only thing there is Gallery,User Tracks and SAMP and USERDATA.DATOMGHost wrote: What u mean system32Dont listen to him, He is trying to mess up your System.
OT:
-Storm
HITMAN_CONTRACT wrote:If you have got windows 7 system 32 it will not work i had that problem formate your computer and make it systeme 62 or some thing like this i forgotIt's not a matter weather it was 64bit or 32bit. It depends upon compability.
