Remove /tune to prevent /tune abuse
16 posts Page 2 of 2
should the /tune command get removed or replaced ?
13%
Yes
2
88%
No
14
Total votes: 16
HITMAN_CONTRACT
Hitman_C
Post by HITMAN_CONTRACT » May 28, 2018, 8:20 pm
I have an idea that may be good if the /tune command gets removed which is Save cars tunning.Evry single player must have tunning models for different cars, for example [Lsrcr]Guest01 must get a car (own vehicule or group vehicule or street vehicule) and go to the tunning garage specified for that car and tune it and save the tunning by a command that must be added for example /TMS(/TunningModelsSave).After he saves the tunning model for Sultan for example when ever he needs the sultan tunned he just use the command /TML(/TunningModelList) and he gets a list of his tunning models that he saved before with tunned car name in front of each model,he will need just to select the Model he needs and click on load and the car he is currently driving gets that tunning model,and also a price for example 500$ for each tunning load may be added.I think this is the best solution if the /tune command is getting removed.
Renegades Owner
Ex-Terrorists Captain,You Can't Escape Death
Ex-Vla Diablito
Ex-LSPD United Officer
Ex-Pagati Associate
S.W.A.T Private
Ex-Army Seargent
Ex-Gambino Member
Ex-Maltesini Caporegime
Indognito
Indognito
Post by Indognito » May 28, 2018, 9:40 pm
It’s fine the way it is, there is no need to change the tune menu unless if they plan on adding more colors, it’s not even a problem when they tune abuse since it makes them an easier target for those who are on the ground, most of the time you can report it since it’s easily noticeable due to the fact that the car legit stops on a dime when they do that, it’s really not that big of a deal and it can be circumvented with only minor issues.
Neelofa
Neelofa
Post by Neelofa » May 29, 2018, 11:33 pm
Good idea, or maybe just save the mods you added on your car from transfender, that means when you tow your car, it will be modded with hydraulics/nitro/wheels etc
Post by Grand » May 29, 2018, 11:37 pm
Robin wrote:
-1, the effort to go all the way to SF just to have your vehicle destroyed not so long after (think about Swat/Army/Cops/cophunters that get into combat all the time) isn't worth it at all and will only be annoying/boring.
Maybe some sort of limit to /tune to activate it when LEOs/hostiles are in close proximity might be the solution here
HITMAN_CONTRACT
Hitman_C
Post by HITMAN_CONTRACT » May 31, 2018, 12:34 am
Better what i said with evry single thing,this will help swats also because they use the swat cars that give them special benifits
Renegades Owner
Ex-Vla Diablito
Ex-Pagati Associate
S.W.A.T Private
Ex-Army Seargent
Ex-Gambino Member
ackman
[Lsrcr]Ackman
Post by ackman » June 1, 2018, 11:54 pm
Since Envious has already sent a PM to CXdur regarding this so I won't bother sending another PM.
I believe Communiy and Poll itself has answered your suggestion very well.
- Suggestion Rejected.
CXdur will probably update the topic if something like this is happening in near future.
About me:
Current memberships:
  • Blackouts
  • DreamTeam
  • Akatsuki
  • NCS
  • Saints
  • VLA
  • Durcrew
  • Beta Tester
  • [Lsrcr] tag.
Activity Status:
  • In-game: 6/10
  • TeamSpeak: 1/10
  • Forums: 5/10
OldSchool:
Return to “Rejected”
