Aleksa wrote:I had similar problem where I had a loose cable, so I bought a new one which was bigger than this one, because I've been using it for PC, TV, phone etc.What cable are you talking about?
Try changing your cable and see if that works, it worked for me. I tested PC 48 hours after this and it never shut down again. I know the feeling, best of luck & hope you fix it.
Robin wrote:Aleksa wrote:I had similar problem where I had a loose cable, so I bought a new one which was bigger than this one, because I've been using it for PC, TV, phone etc.What cable are you talking about?
Aleksa wrote:I had similar problem where I had a loose cable, so I bought a new one which was bigger than this one, because I've been using it for PC, TV, phone etc.Nahh, my PC shut down because of powercut in my area.. and I think I'll install new windows since I tried many things but none of them worked.
Aleksa wrote:Oh you mean the power cable.Robin wrote:Aleksa wrote:I had similar problem where I had a loose cable, so I bought a new one which was bigger than this one, because I've been using it for PC, TV, phone etc.What cable are you talking about?
Try changing your cable and see if that works, it worked for me. I tested PC 48 hours after this and it never shut down again. I know the feeling, best of luck & hope you fix it.The main oneSpoiler: show
Robin wrote:Yeah and it worked. Everything is working fine now..Aleksa wrote:Oh you mean the power cable.Robin wrote: What cable are you talking about?The main oneSpoiler: show
@ackman tried restoring a backup?
ackman wrote:Well, it only worked well until I didn't shut down.. again sameRobin wrote:Yeah and it worked. Everything is working fine now..Aleksa wrote:Oh you mean the power cable.The main oneSpoiler: show
Thank you, Robin
ackman wrote:My PC turned off directly (twice/thrice) 2 days ago due to power cut since than I'm getting constant FPS drops in SA-MP and it's also freezing for few seconds on CS:GO Start up screen and my PC is also working slowly, like freezing for 2-3 seconds on welcome screen, used to connect in CS:GO competitive match within 30-40 seconds but now it takes around 4 minutes to connect in a competitive match, etcBuy a new Pc
Any idea how to fix this issue without reinstalling a new windows? I tried clearing dust from inside of PC (Changed ram slots, cleared dust from processor) and also tried restoring system at an earlier point but still couldn't fix this issue. Help would be appreciated.
