Kaosx234 wrote:Another Carsx234 version...GuitarJohn wrote:-1You do realise what you are talking about? Keybinders do /cuff [blank], they won't do for each player keybind for God sake. Please insert some IQ into your brain
Would make it easier for keybinders.
Naruk wrote:I had this in mind sinc ages but meh, literally seeing IDs gives us a little bit challenge. Everything would be easier now and would decrease the rate of LEO's SOC failure, giving LEOs another perk.If you are going to use this as an argument, then we should put IDs just what is in the captcha, not to be visible at all - maybe you should suggest that in the nearby future.
-1
Zoroark wrote:I've given people in game moneyHis life is fulfilled now
Kaosx234 wrote:Having the same way of how you "logically" think, I suspect that we should just not put any ID/Name at all - and you should modify your suggestion right now.Naruk wrote:I had this in mind sinc ages but meh, literally seeing IDs gives us a little bit challenge. Everything would be easier now and would decrease the rate of LEO's SOC failure, giving LEOs another perk.If you are going to use this as an argument, then we should put IDs just what is in the captcha, not to be visible at all - maybe you should suggest that in the nearby future.
-1
The ID is supposed to make our job easier but yet, sometimes it is harder.
And Naruk is becoming Robin v2.0.
Naruk wrote:I'd agree with that suggestion but it clearly is not possible (the only way is to taze the closest person but in some situations it is worse), I prefer adding names, RobinKaosx234 wrote:Having the same way of how you "logically" think, I suspect that we should just not put any ID/Name at all - and you should modify your suggestion right now.Naruk wrote:I had this in mind sinc ages but meh, literally seeing IDs gives us a little bit challenge. Everything would be easier now and would decrease the rate of LEO's SOC failure, giving LEOs another perk.If you are going to use this as an argument, then we should put IDs just what is in the captcha, not to be visible at all - maybe you should suggest that in the nearby future.
-1
Our job is already very easy, criminals are being stomped upon, and you want it easier? Please Carsx234
Naruk wrote:Please, do not turn this topic into a wanna-be-bar section. Keep trolling there.davidscorp13 wrote:Naruk, just give up... Don't even try to debate with him it will only lead to unlimited thingyUhh, I've been nailing him lately though, kaosux bigtime
