Zoroark wrote:I've given people in game moneyHis life is fulfilled now
GalaxyGeri wrote:What if there are to players with the same name?Sometimes you're forced to taze during a fight and you can't see the IDs because they're running too fast, this suggestion can solve it.
Like [Lsrcr]GalaxyGeri and Galaxy? You will type /taze galaxy and who will you taze.
This think is in minecraft too, but when you press like ga and then TAB it will pop up all the names.
Neutral.
GalaxyGeri wrote:What if there are to players with the same name?You might want to re-read my suggestion, to the bottom. I explained that situation. You also want to check the bolded part.
Neutral.
Kaosx234 wrote:Aight after i read it all i am fine with it and it is a perfect suggestion.GalaxyGeri wrote:What if there are to players with the same name?You might want to re-read my suggestion, to the bottom. I explained that situation. You also want to check the bolded part.
Neutral.
