HunTeR1 wrote:Wonder what happens if you fist someone in hes anusFreestyle wrote:Still hotJohnCarer wrote:tits n nipples
Boone wrote: you need to focus on your nutrition, abs are hidden under the belly fatI have to take this very slowly as when I decrease amount of calories and add more cardio, I lose mass on my arms and shoulders. You can see my abs but not as defined, as this process takes a long time and proper nutrition, as you said. Losing fat and gaining muscle at the same time is the hardest process in body
JohnCarer wrote:I take it you started fat. Well, at this point I'm not much experienced because I never was fat, don't know the feeling either. You should actually burn more calories than you consume in order to gain muscle. Standard crunches will basically burn your belly fat. Believe me, a bulky body missing abs is like a house missing windows. Abs are essential if you want to look real attractive if you know what I mean.Boone wrote: you need to focus on your nutrition, abs are hidden under the belly fatI have to take this very slowly as when I decrease amount of calories and add more cardio, I lose mass on my arms and shoulders. You can see my abs but not as defined, as this process takes a long time and proper nutrition, as you said. Losing fat and gaining muscle at the same time is the hardest process in body
Boone wrote:I don't want to be rude but what you said is bs, lol. Less broscience
You should actually burn more calories than you consume in order to gain muscleNo, very wrong. Those 2 processes are different and got pretty much nothing in common. Anabolism and Catabolism, search them up.
