Matta wrote:From the experience that I had in Ls-rcr, was a pretty repetitive experience. I'm not saying is bad it's pretty addictive but I think more content added would make the experience much more exciting for even new players as well. Here's some class suggestions.Use the template.
Bus Driver:
Since there are alot of stages around each town [Los Santos, San Fierro, Las Venturas], you could have different routes. Depending on the route, you'll have directions where to head to next and when completing all checkpoints you'll be awarded an amount of cash and 1 score for an instance. Also could be added in your stats as a Bus driver.
Farmer:
You could have two types of farmers, legal and illegal. Could buy the crops needed from the barn, plant them using a tractor. Once that is done you wait for them to grow and harvest them using the harvester vehicle [Legal]. Illegal would pretty much be the same, for instance you plant weed instead of normal crops and when you do that you get instantly Wanted. Basically taking the risk of getting caught but it would be a good pay + 1 score. Could be added to stats.
Re-work Hitman Class or Assassin as another class:
So pretty much a hitman job right now, is simply taking out the hits that people put out. What if we add a little twist to it? I think there should be a specific place to spawn as a hitman and there should be added a cupboard where you can disguise yourself as another class. When you do that, the color changes depending on that class.
For instance, you need to take out a police office, so you disguise yourself as a cop and your color changes to blue as well. If you as a hitman shoot the specific target, your cover is blown and you instantly change back to your normal hitman color.
Note that imma keep brain storming and editing the topic.
Ghetto wrote:+1 this will be interesting and will make the game more enjoyable.
Matta wrote:[500+ hitmen score only, great idea.
Your name: mATTA
Suggestion headline: Re-work Hitman Class or Assassin as another class
Picture: None
Importance of suggestion: 10/10
Why should it be accepted:
Milyn wrote:Its a positive from me everything made sense +1.Matta wrote:From the experience that I had in Ls-rcr, was a pretty repetitive experience. I'm not saying is bad it's pretty addictive but I think more content added would make the experience much more exciting for even new players as well. Here's some class suggestions.Use the template.
Bus Driver:
Farmer:
