Disallowing usage of 'C' if miss-switched [ACCEPTED]
44 posts Page 1 of 5
BeaTen.
BeatEn
Post by BeaTen. » May 20, 2019, 11:01 pm
Your name: BeatEn
Suggestion headline: Disallowing usage of pressing the button 'C', when we miss-switch
Importance of suggestion: 5/10
Why should it be accepted: C bug is not allowed here in this server (at least with deagle), but still its very easy to C bug and say, 'I miss-switched', when you miss switch while dueling, its not anyone's fault that you miss-switched, its your own fault and you should not be able to C bug just by blaming your switching skills. If you don't understand what I'm talking about, I'll explain it to you; while you are using 2shot with sawnoff, sometimes while switching, you are unable to switch back to sawnoff and mistakenly, you shoot with deagle, now when you shoot with deagle, it triggers the deagle shot animation which can be avoided by pressing C, which is C bug(if done repeatedly, but still is avoiding animation using unfair means). This way you can just switch, and fail intentionally and c bug, even if you don't fail intentionally that doesn't mean that you will start using C to avoid the animation.
This can be easily avoided by just adding an auto freeze when someone does this (I've seen this in other servers), or just simply making a rule that this is not allowed.
XXOOOOXXOXXXXXOXXXXOXXXXOOOOOOO
XOXXXXOXOXXXXXOXXXOXOXXXXXXOXXXX
XOXXXXXXXOXOXOXXXOXXXOXXXXXOXXXX
XXOOOOXXXOXOXOXXOOOOOOXXXXOXXXX
XXXXXXOXXOOXOOXXOXXXXXOXXXXOXXXX
XOXXXXOXXOXXXOXXOXXXXXOXXXXOXXXX
XXOOOOXXXOXXXOXXOXXXXXOXXXXOXXXX
(Credits: TheDragon.)
VenoM
VenoM
Post by VenoM » May 21, 2019, 1:22 am
Great suggestion. I've been always against this thing because it has always promoted c-bug and players always do it and say mistake.
Jostafa
Jostafa
Post by Jostafa » May 21, 2019, 1:30 am
I Agree Beaten Nice suggestions.
e.e
e.e
Post by e.e » May 21, 2019, 2:05 am
BeaTen. wrote:
Your name: BeatEn
+1
a reason why I always disarm my deagle is: if you miss switch - you'll punch with your fist which won't make you stand still
a rule is a rule and shouldn't be ignored, just cause you fuck up your switches.
Mr.DollarMan
Mr.DollarMan
Post by Mr.DollarMan » May 21, 2019, 7:02 am
It's a good suggestion and I support it.
The senior admins and developers should also realize that there are players who are still taking unfair advantage from one of the animations which should be dealt with. That animation is "Entering a vehicle as a driver or passenger" by pressing F or G during a duel/fight for multiple reasons. By pressing F or G during a fight it gives the player the unfair advantage to avoid damage for a 2-3 seconds and prepare a command within that time. The commands can be of taking drugs/injections, tazing, cuffing or arresting.
It's not allowed to abuse any animation then why is this any different? The seniors admins should find a good solution for this as well.
Signature Credit: King_Mahathir.
BeaTen.
BeatEn
Post by BeaTen. » May 21, 2019, 7:24 am
Everyone does that because it is not stated in the rules that its not allowed, however it is scriptable to make the player take damage while he is entering the vehicle as a driver/passenger
Balsa
[Lsrcr]Balsa
Post by Balsa » May 21, 2019, 9:49 am
+1
Santiago
[Lsrcr]Santiago
Post by Santiago » May 21, 2019, 6:13 pm
I agree, there should be an auto freeze when you c bug EXCEPT when you are at fightclub since I still believe there should be a place for such duels
killdahobo99 wrote:
Santiago wrote:
fuck u
listen here u fucking mexican little turd. I will molest you in the mouth while your dog watches and then I'll fuck your dog while you watch.
Mr.DollarMan
Mr.DollarMan
Post by Mr.DollarMan » May 22, 2019, 9:31 am
I know that it isn't written in the rules but if we think about it, isn't it an animation abuse? Do you want that something should be done for this animation abuse or not?
Post by Robin » May 22, 2019, 10:00 am
Lsrcr rules wrote:
C-Bug is not allowed and is bannable.
As far as the rules state it's currently not allowed as well...
Am I missing something or is it just poorly enforced?
Return to “Accepted”
