Muawwiz wrote:2: You can't use Hydra if the mw suspect is teaming with orange wanted suspects.what if they are in airborne/waterborne? still cannot engage using hydra rockets?
Muawwiz wrote:3: You don't need to ask for /su before using RPG. RPG is only used on mw and highly wanted suspects if they are in a flying vehicle, you can not use it on orange wanted suspects if they are alone but you can if they are teaming with highly or mw suspects.ye, so if orange suspect teaming with highly wanted suspect or most wanted suspect in airborne/waterborne, i still can shoot with rpg without using /su?
Diplomatic. wrote:Muawwiz wrote:2: You can't use Hydra if the mw suspect is teaming with orange wanted suspects.what if they are in airborne/waterborne? still cannot engage using hydra rockets?
Answer:
Air and water restrictions doesn't matter when there's orange suspect teaming with Most Wanted.Muawwiz wrote:3: You don't need to ask for /su before using RPG. RPG is only used on mw and highly wanted suspects if they are in a flying vehicle, you can not use it on orange wanted suspects if they are alone but you can if they are teaming with highly or mw suspects.ye, so if orange suspect teaming with highly wanted suspect or most wanted suspect in airborne/waterborne, i still can shoot with rpg without using /su?
Answer:
You're not allowed to engage if there's a orange teaming with highly wanted suspect or most wanted suspect.
Ahmed. wrote:about your second answer... actually we canDiplomatic. wrote:Muawwiz wrote:2: You can't use Hydra if the mw suspect is teaming with orange wanted suspects.what if they are in airborne/waterborne? still cannot engage using hydra rockets?
Answer:
Answer:
Ahmed. wrote:Oh ye right , my bad mixed up the hydra and rpg rules.[/quote]about your second answer... actually we canSpoiler: show
You may use the RPG on medium wanted suspects who are teaming with highly wanted suspects & most wanted suspect (considering they are airborne/waterborne).
i copied it from rules section but anyways my question was i must use /su before doing so or not
Diplomatic. wrote:No you don't need to /suAhmed. wrote:about your second answer... actually we canDiplomatic. wrote: what if they are in airborne/waterborne? still cannot engage using hydra rockets?
Answer:
Answer:
Diplomatic. wrote: First one (Hydra jet related):
Rules copy/paste says: You may engage highly wanted suspect or the most wanted suspect in air with Hydra without using /su (also applies when they are on ground in a flying vehicle).
The question is: How about waterborne? It only stats if he is in air. So how about highly wanted suspect teaming with most wanted suspect in waterborne? Can I engage using hydra jet rockets as well or not?
Sinner wrote:are not we allowed to engage highly wanted suspects when they are in water either alone or with orange?Diplomatic. wrote: First one (Hydra jet related):
The question is: How about waterborne? It only stats if he is in air. So how about highly wanted suspect teaming with most wanted suspect in waterborne? Can I engage using hydra jet rockets as well or not?Answer:
Hi, you may not engage the highly wanted suspect (red color) if he's alone in water as there's no specified rule for it, in cases when there's no rule specified we consider the general rule for it, as in your case the general rule is the rule used on land. In cases if a highly wanted suspect is teaming with a most wanted suspect in water, you may then engage them AFTER using /su and waiting for the timer to expire (unless you've been attacked by any of them). However, it may be changed in near future. - For any further queries, feel free to reply here, keeping it unlock for 24 hours.
Colonel Sinner
