♠️ S.A.S.F - F.A.Qs ♠️
Serving today for a better tomorrow!
Moderator: S.A.S.F. Commanders
1 post Page 1 of 1
Panda
[Lsrcr]Andro
Post by Panda » July 2, 2019, 4:56 am
Q: How much score is needed to join the S.A.S.F?
A: At least 500 score and 150 Arrests
Q: Can I vote on applications If I'm recruited in the group?
A: Yes, you can vote on applications as soon as you get accepted.
Q: Is there a template on voting?
A: You may use your own format on voting.
Q: Can I ask to be a tester in the group?
A: No, Askin for promotion or anything like this will lead you into a warning or worst kick/blacklisted
Q: Can I post an unblacklist appeal?
A: Yes, but make sure that you'll post it on the correct page/topic.
Q: Can a Leader recruit someone without any requirements and test?
A: Yes, only a leader can.
Q: I see a high ranked member online - should I /pm him and ask him to test me?
A: No, you may not not all high rank is a tester but if you see a tester online then you can /pm him and ask him to test you. If the tester says he's busy and can't test you right now, then don't spam him with the pm's.
Q: Can I be in other mafia/gang if I'm in this group?
A: You are allowed to join any group while being a member.
Q: Is this group a Roleplaying group?
A: Yes, but not more on RP group.
Q: Can I bribe the group and join it?
A: No if you do it will lead you into Blacklist for one month
Q: How much time do I have to get tested after I applied?
A: You've 7 days to get tested, starting from the date you have applied.
Q: When are promotions held? Can I ask to be promoted?
A: We do promotions whenever we think it's the right time. Asking for a promotion will lead to demotion.
Q: How to apply for the S.A.S.F?
A: You need to submit an application with the given format.
Note: More F.A.Qs will be added soon.
1 post Page 1 of 1
Return to “San Andreas Special Forces”
