C.R.A.S.H. Rules
Moderator: C.R.A.S.H. Chiefs
1 post Page 1 of 1
Vic
Post by Vic » November 5, 2019, 1:25 pm
* You must follow server rules at all times. Breaking server rules can lead to a harsh punishment depending on the severity of the offense.
* Causing harm to any of the C.R.A.S.H members in-skin will lead to a harsh punishment.
* You are not allowed to go AFK on spawn point. Failing to comply with this order will lead to a warning and in some cases, a kick.
* You must obey every order of your senior. This doesn't mean that you should follow an order that's against the server rules. You should report such orders to a staff member along with proof. Seniors do not have the authority to put you and the image of the group at risk.
* The hidden code under ur application:
"Unit-G"
* You can not go inactive for more than 15 days without posting a status update. Doing so will lead to addition of warnings and eventually a kick.
* You can go inactive for up to 90 days if you have posted a status update.
* You are not allowed to use the possessions of the group if you haven't spawned in the group.
* You must upload a proof of your statistics from the An ingame / stats screenshot will not be accepted and will lead to the application being invalid.
* You cannot copy someone else's application reason, your previous application reason won't be accepted either.Failing to comply with any of these will lead to the application either being invalid or straight up denied.
1 post Page 1 of 1
Return to “Office”
