getrektdude wrote:So i assume that you're trying to say that,I think what Getrektdude said covers it all. You are supposed to work as a team. If someone 'steals' your suspect then let it be, in the end you all have the same goal.
If, a cop cuffs someone, another cop should not be able to arrest that suspect.
Well, as a cop you work as a team against criminals, it's not really troublesome when someone arrests the suspect which was cuffed by you, unless they do it constantly in order to provoke you or annoy you intentionally which is reportable in most cases.
It's not a major problem when someone allegedly steals your suspect, so it's just fine the way it is as of now.
