A few changes to S.W.A.T. faction
If you have a new idea that could benefit the team, feel free to share it here!
ImLander009
Lander
Post by ImLander009 » June 11, 2020, 10:58 pm
Your Name: [Lsrcr]Lander
Your suggestion: Add a red checkpoint at Alcatraz island at which we can arrest the dragged suspects there, and update the drag rule regarding making this surrounded area free to drag many suspects whether you are playing solely or not
Reason: Greetings everyone, so i have come up with a new fresh suggestion which is "adding a red checkpoint at Alcatraz island to hand the dragged suspects there, and update the drag rule as mentioned above".
So, honestly i have seen a lot of S.W.A.T. members drag suspects there but they road their vehicle for a long distance to hand them at Dillimore or any other nearby checkpoint, so why not adding a checkpoint there, at which we can hand them without even wasting both the suspects time, and the S.W.A.T. time
Your suggestion: Add an ATM in Los Santos S.W.A.T. base which allows you to only withdraw a specific amount of money.
Reason: Adding an ATM in the S.W.A.T. base is a useful idea because some members when they spawn, they be out of money, and hence, they cannot buy injections, wallet, cork ...etc
Both suggestions ideas go to [Lsrcr]Grand and [Lsrcr]Lander
Veen
[Lsrcr]Veen
Post by Veen » June 11, 2020, 11:23 pm
For the checkpoint suggestion, Yes it could save time for both parts, but there're some criminals that prefers this long distance so that they have the opportunity to use /bc, so im neutral.
For the last one, it did indeed happen a lot of times with me , especially after the V9 update that i found my self without money after the spawn, i don't really find it a huge problem since it prevents us only from buying the 24/7 items and it could be solved by dragging or killing few suspects,However, i noticed also that there's no atm in ocean docks or willowfield so why not add one near the base if it's possible.Positive
Playa
Playa
Post by Playa » June 12, 2020, 8:31 am
Hi,
We already had the first suggestion made a while ago and it was decided that we are not going to be adding a checkpoint at Alcatraz because it takes some effort for the criminals to break individuals out and if we arrest them right there and then, it reduces the interaction and does not give them a chance to break free. However, there were two other checkpoints added in Angel Pine Sheriff Station and El Quebrados Sheriff Station. Use those if need be.
As for the second suggestion, the whole point of having members purchase items is to not give them everything for free. We already get free weapons, cars, and other amazing features that come with a faction. There is no need for an ATM in base or even adding one nearby for that matter. Not everything should come easy to us and a little bit of work keeps the gameplay going.
Both suggestions are going to be denied at this point of time.
Add me on steam!
Return to “S.W.A.T. || Suggestions”
