Score Limit the train [ACCEPTED]
22 posts Page 1 of 3
Karu_Tepes
[Lsrcr]Lost_Soul
Pagati Don
Event Host Blackmarket VIP
Post by Karu_Tepes » November 17, 2020, 6:51 am
Your name: [Lsrcr]Karu_Tepes
Suggestion headline: Score Limit the train
Importance of suggestion: 8/10
Why should it be accepted: I've been seeing this more and more lately, but new players (usually under 10 score) get into the train at Union Station, drive it up a ways and block the crossing from Idlewood to LSA, or up into the blackmarket area. Blocking off key roads is bad, but more of the time they /lock the train then log out, making it IMPOSSIBLE for us to move it. I've had to move the train so many times, and a few times I've had to have staff reset it. I think a better solution to this growing issue, since it's happening more often, is to set a score limit of 1000+ to drive the train.
Faraon78910
Post by Faraon78910 » November 17, 2020, 10:21 am
Just as a newbie can block the road, player over 1000 score can do it too. This is not the solution. I did experience train blocking the road, but not that often to cause huge problems. You can always turn left/right and end on road you wanted to drive on. -1
Karu_Tepes
[Lsrcr]Lost_Soul
Pagati Don
Post by Karu_Tepes » November 17, 2020, 10:46 am
I would expect a player with 1000+ score, or even 500+ score, to know better than to do it. It can seen as bitching/community annoyance. So at 1000+ score, you know better.
Fantastic
[Lsrcr]Fantastic
Post by Fantastic » November 17, 2020, 11:01 am
Or make it so that only tagged members can operate it
Balsa
[Lsrcr]Balsa
Post by Balsa » November 17, 2020, 11:41 am
I am going to agree with him. As many people are just using train to block some main roads in samp. It's annyoing really...
Milyn
Milyn
Blackmarket VIP
Post by Milyn » November 17, 2020, 12:09 pm
Why so? Explain !
Fantastic
[Lsrcr]Fantastic
Post by Fantastic » November 17, 2020, 12:26 pm
Milyn wrote:
Why so? Explain !
Most is explained by Karu already. The train is often misused for annoyance purposes and more often than not requires staff intervention to remove the obstruction (as in most instances perpetrators lock the vehicle). We can easily prevent the misuse of it by making it a tagged member privilege, that way ensuring the train is used in a sensible manner. Similar to the current restrictions on the tow truck.
Milyn
Milyn
Blackmarket VIP
Post by Milyn » November 17, 2020, 12:35 pm
Fantastic wrote:
Milyn wrote:
Why so? Explain !
if I would like to drive the train how would I be able to do so? i enjoy driving the train this is not at all a perfect solution. The best way is to add a score limit or a short respawn timer for the train alone.
Fla$h
[Lsrcr]FLA$H
Post by Fla$h » November 17, 2020, 1:20 pm
Milyn wrote:
Fantastic wrote:
Milyn wrote:
Why so? Explain !
I think that making the respawn time shorter is the best solution just like the helicopters in alca they respawn so fast tho.
GuitarJohn
Guitarjohn
Post by GuitarJohn » November 18, 2020, 5:21 am
Seems logical, positive from me.
Return to “Accepted”
