READ THIS PRIOR TO POSTING IN THE REPORTS SECTION
1 post Page 1 of 1
Andrew
Andrew
Post by Andrew » November 30, 2020, 6:55 pm
Hello, and welcome to the report section. We're sorry you may have had a bad experience with another player in the game and ask you share some of the information with us here.
We ask that you read and follow these instructions prior to making a submission in this section. Failure to follow these instructions could result in punishment up to a permanent ban, so please read them completely before posting.
Is your report sensitive, or do you feel it is absolutely necessary to keep it secret from anyone who can read this forum? Is your report accusing someone of using an aimbot or keybinder? If you answered yes to either of these questions, please follow the below instructions, but instead of submitting it as a topic to this section, please send it as a private message to an administrator here on the forums. You can find a list of these users here. If the administrator determines it to be unnecessary to handle the report privately, they may require you to re-post it in this section.
Are you reporting a staff member? If so, please follow the below instructions, but instead of submitting it as a topic to this section, please send it as a private message to an assistant senior administrator or higher rank for review. You can find a list of these users here or here.
Report Section Rules
  • Do not report someone for something that is not against the rules. Certain rule violations are also not reportable here. These include: minor insults and reporting on behalf of others.
  • Do not post in this section unless you possess useful information pertinent to the report you are posting in. This also restricts the reporter or reportee from posting irrelevant information on their own reports.
  • Do not argue or post inflammatory remarks.
  • Do not edit your evidence in a way that could lead someone believe it could be "doctored". For example, clipping a 10 minute clip down to the relevant 2 minutes would be okay, but cropping a screenshot would not be okay.
  • Do not report hunt or report someone for a minor violation of the rules that caused no inconvenience to you or others. For example, following someone around for an extended period of time in an effort to get them to react in violation of the rules, then reporting that player for rule-break would be considered report hunting.
  • Do not report someone for something that could have been handled by an online administrator at the time or for something that is easily avoided by an in-game function. For example, someone insulting you in PMs is easily avoided by using /ignore <id>, but someone insulting you repeatedly in main chat would not be easily avoided.
  • Characters limit to '100' on field 'anything else' to make reports as brief as possible.
  • Single DM is not reportable anymore.
  • Taking rules out of context will now be punishable as 'report hunting'.
  • Minor insults will no longer be punishable. Only serious insults where it's clear there's intention of harassment will remain punishable.
  • Do use the correct format as listed below:
Format
  • TITLE: PLAYER NAME - REASON FOR REPORT
  • CONTENT:
    Code: Select all
    [b]Your name:[/b] (your in-game name)
    [b]Their name:[/b] (the rule-breaker's in-game name)
    [b]Reason:[/b] (why you are reporting them) [single dm is not reportable]
    [b]Proof:[/b] (proof of the rule-breaks in images or videos)
    [b]Anything else:[/b] (any other information that could help staff resolve the problem)[MAX 100 characters]
1 post Page 1 of 1
Users browsing this forum: dev3r3r and 2 guests
