Spetsnaz application: [Lsrcr]TomaHawk [ACCEPTED]
Accepted applications will be found here.
Moderator: Spetsnaz HC
Accursed
[Lsrcr]Accursed
Post by Accursed » September 29, 2021, 2:12 pm
Your name: [Lsrcr]TomaHawk
Statistics: https://imgur.com/a/vK5jBoh
Timezone & Country: GMT +8 / Malaysia
Reason: Well as I said, I will be back once someone who truly deserve to lead it once again and here you go I can see a reform from Spets managements. Of course the main reason I would to join is because I am quite active as leos, I guess most of the times I used to play in army skin instead of civil.
Nothing much to mention here, I'll try my best to represent the group once again.
Spetsnaz11
Mockery
[Lsrcr]Mockery
Post by Mockery » September 29, 2021, 2:15 pm
Hello, Thank you for applying.
Before we can accept or deny you, you must pass our test which will test your knowledge of Server Rules and The Spetsnaz Rules. You will be tested by one of our Recruitment training officers(RTO). Do not annoy or spam them, be patient. You must score at least 13/15 in rules awareness in order to continue with your application.
Make sure you join our discord server before applying. Click me to join
You can request to be tested by one of our Recruitment Training Officers.
Recruitment Training Officer - [Lsrcr]Mockery
Recruitment Training Officer - [Lsrcr]Geri
Good luck with your application.
The maximum time period to get tested is 7 days, get tested in 7 days since you post your application or it will be auto-denied. If any tester approaches you for test you can't say "I want to get tested by any other tester".
You should always be ready to give test when you apply for Spetsnaz unless you have a valid reason.
Mockery
[Lsrcr]Mockery
Post by Mockery » September 29, 2021, 2:45 pm
TEST RESULTSRules awareness: The applicant was given 15 questions, he answered correctly to 15 questions out of 15.
PASSED
Mockery
[Lsrcr]Mockery
Post by Mockery » September 29, 2021, 2:48 pm
  • The High Command has decided to ACCEPT your application.
  • If you've any questions regarding the group, do not hesitate to ask the High Command.
  • The rights for in-game base/features granted.
  • Have fun and make sure to well represent us.
Return to “Accepted Applications - Old spetsnaz”
