Funderburk wrote: Server side
- Disallow multiple ip connections at the same time unless whitelisted. We shouldn't restrict someone's gameplay because they play on the same IP - applying for a whitelist is easy yes, but this will guarantee that cafes won't receive a whitelist because they are mostly children who can't write basic English.
- Add permanent ban to [lsrcr]arthur [lsrcr]flash [lsrcr]ackman This just sounds like a troll
- Add a votekick or timeout function for LSRCR members to vote possible cheaters out of the server when staff arent available. I know why you would suggest this, but I don't think players shouldn't be given this power, no matter how trusted. If anything, improve the anti-cheat where possible.
maybe more to come but first ban arthur flash and ackman thanks
FeinT. wrote:But you know this will never be implemented rightWhy bother commenting if you're not even going to explain why it wouldn't be implemented?
OkaManThe$Wolf wrote:all what you mentioned not necessary actually and how all members able to use SWAT BOMB it's not possible Of Course because there a Special rank to use nevertheless if you would make anything Regarding Swat suggest it on inside section in SWATAll of what i mentioned is necessary until you have some sort of actual input as to why its unnecessary
Abstract wrote:just cafe things....FeinT. wrote:But you know this will never be implemented rightWhy bother commenting if you're not even going to explain why it wouldn't be implemented?
I think if enough people get on board with these suggestions, at least half could be accepted.
