Factory Drug Production Guide
Find all the available roleplay guides here.
Moderator: Pagati Leaders
FeinT.
Feint.
Post by FeinT. » November 28, 2021, 6:25 pm
Drugs Producing
IntroductionAs most of you know, some updates were issued to pagati lately, and the Drug Factory system & how it works was kinda changed completely, in this topic, you will know everything you need to know about how it works, if you are still in doubt about something, feel free to leave a reply here.
The steps
1: Buying the kit.
First thing you will need to do is, buy a kit from Leory (an NPC that can be found on Ocean Docks). It is preferred that you use a chopper to speed up the operation. After you land successfully, you just approach the NPC and buy a kit at the cost of 1.5K each. Keep in mind that you can buy 2 kits maximumly. You will get dizzy when you buy a kit tho due to toxicity of the chemicals. (You can see in the third pic)
2: Producing the drugs.
After buying the kits, directly head back to the headquarter, where's as we will be producing the drugs, specifically in the Drug Factory.
But wait! You will need another player (Pg member ofc') to help you. Luckily mr.sultan was online and he helped me throughout the producing process.
So both of you enter drug factory, you are supposed to produce drugs, and the other guy(mr.sultan in this case) should check machinery, then you wait until you are done producing (1 minute).
3: Loading the truck with drugs
Well, you are almost getting there! After finishing the first 2 steps, there are 2 steps left, which are filling up the trailer with drugs and delivering it, this could be considered as a one step but to clarify things up, I just wanted to split them up. So when you exit the drug factory, you will see a checkpoint, and exactly next to the checkpoint, there is a Roadtrain(a vehicle), So you get in that vehicle and attach a trailer to it.
Now you are in the roadtrain, head to the checkpoint, a textdraw would appear, you will have to wait 20 seconds to fill up the trailer with drugs.
4: Delivering the drug
Well, you made it to the last step, now when it's done loading up drugs, you will get a dialog like this:
It's similar to airdrop, but you know what we are going to have a hard time doing... delivering the drugs, because roadtrain is a pain in the backside to drive, so you're better off choosing "Dillimore" because it's the closest location to Blueberry(Pagati HQ). Now you will see a little flag in your minimap, you just follow it till you make your way to the checkpoint, now look how you easily made 10K!
The endThis new feature is so cool, if you are a pagati member you must try it out because you can make 100K daily easily. And I would like to thank Don Shah and all the other developers who worked on this new feature, and especially you who was patient reading this guide, hopefully you liked it, if there's anything I can fix/add, please don't forget to leave a comment!
Criminal
[Lsrcr]Criminal
Radio Manager
Post by Criminal » November 28, 2021, 7:53 pm
Amazing tutorial/guide, well explained!
Former Pagati Don | Spetsnaz Marshal | S.W.A.T SPC
Return to “Guides”
