The Rulers | How to apply [UPDATED]
Moderator: The Rulers Staff
1 post Page 1 of 1
Lucas123
Lucas123
Post by Lucas123 » March 8, 2022, 9:49 pm
THE REQUIREMENTS
  • 1500 score in general, 200+ hours of playtime and must be matured enough.
  • Great understanding of the The Rulers group, including the Group rules, and Server rules
  • Good English knowledge
  • Good activity active in-game
  • Good set of skills
- You should to send 75k to CFO/CEO only
Note: If you're not following the format given below, Your application will straight away get denied!
[legendary=Brown,white,]Filling out an application Application title[/legendary]
Code: Select all
✵ The Rulers Application ✵ : [Your ingame name]
Code: Select all
[quote][hr][/hr][center][img]https://i.imgur.com/s4VeNVe.png[/img][/center][hr][/hr]
[b]Name:[/b]
[b]Proof of Status: [/b]
[b]Country - GMT:[/b]
[b]Playtime:[/b]
[b]Score: [/b]
[b]Reason: [/b](Explain to us why do you want to be guard?)[/quote]
Notes:
  • Do not interrupt the staff team or tester to test you when they're busy.
  • Do not flood the staff team or tester to test you.
  • When the staff team or tester asks you to come to the base to take the test, do the test and you're not allowed to refuse unless you have a valid reason for leaving.
  • If you forgot something important with the template, you'll be automatically denied without any hesitation.
Once you've correctly submitted your application, we will be responding with the testing left template for your application.
Best of luck with your application!
1 post Page 1 of 1
Return to “Applications”
