Spetsnaz application: [Lsrcr]SultaN [DENIED]
Denied applications will be found here.
Moderator: Spetsnaz HC
Mr.sultan
SultaN
Post by Mr.sultan » April 1, 2022, 10:57 am
Your name: [Lsrcr]SultaN
Statistics: https://imgur.com/a/bLc1a2J
Timezone & Country: GMT+8 Philippines
Reason: Ay folks!, I came here to apply Spetsnaz and this is my first application to apply since the group has been updated which is requirements that I already meet. I've read rules the group rules carefully. I do active as Medic and as well as in cop skin and keep cleaning the Ls-rcr streets, teaming with fellow members, and team working up to arrest those criminals. That's all, thanks for reading!
Spetsnaz 1
Accursed
[Lsrcr]Accursed
Post by Accursed » April 1, 2022, 12:27 pm
Hello, Thank you for applying.
Before we can accept or deny you, you must pass our test which will test your knowledge of Server Rules and The Spetsnaz Rules. You will be tested by one of our Recruitment training officers(RTO). Do not annoy or spam them, be patient. You must score at least 13/15 in rules awareness in order to continue with your application.
Make sure you join our discord server for any information or updates.
You can request to be tested by one of our Recruitment Training Officers.
Recruitment Training Officer - [Lsrcr]ExperimenTaL
Recruitment Training Officer - [Lsrcr]Bear
Recruitment Training Officer - [Lsrcr]Inzane
Good luck with your application.
The maximum time period to get tested is 7 days, get tested in 7 days since you post your application or it will be auto-denied. If any tester approaches you for test you can't say "I want to get tested by any other tester".
You should always be ready to give test when you apply for Spetsnaz unless you have a valid reason.
Razor
[Lsrcr]Razor
Event Host Supporter
Post by Razor » April 1, 2022, 1:28 pm
TEST RESULTSRules awareness: The applicant was given 4 question, he answered correctly to 1 questions out of 4.
FAILED
Tamer wrote:
Razor
[Lsrcr]Razor
Post by Razor » April 1, 2022, 1:29 pm
  • Sorry, but the High command has decided to DENY your application.
  • The applicant failed to correctly pass the test.
  • You may re-apply in 14 days.
Tamer wrote:
Return to “Denied Applications - Old spetsnaz”
