BeaTen. wrote:Your name: [Lsrcr]BeatEnI know you are not murrican but this is the difference from a 9mm from a desert eagles .50 AE
Suggestion headline: Nerf deagle and Uzi damage values
Importance of suggestion: 7/10
Why should it be accepted: Ever since the damage registration was fixed, it's now too accurate and Uzi does a deadly amount of damage (so does the deagle), and since the sawnoff is nerfed, using Uzi, you can kill a guy within 2 seconds if done right. Deagle does very lethal damage too, you can easily kill a guy using deagle (not if the other guy is using Uzi because Uzi will obliterate any stationery target)... So what I suggest is make deagle dmg -30HP per hit and Uzi damage maybe like -5HP or something per successful hit registration
Funderburk wrote:Yes and if we follow IRL concepts that you will be kicked permanently when u die in-game because u don't spawn again after dying irlBeaTen. wrote:Your name: [Lsrcr]BeatEnI know you are not murrican but this is the difference from a 9mm from a desert eagles .50 AE
if anything deagle should be buffed or removed if players dont like it
BeaTen. wrote:I am all for this featureFunderburk wrote:Yes and if we follow IRL concepts that you will be kicked permanently when u die in-game because u don't spawn again after dying irlBeaTen. wrote:Your name: [Lsrcr]BeatEnI know you are not murrican but this is the difference from a 9mm from a desert eagles .50 AE
