LikeWise wrote:Yes, I said "no worries" because I wasn't even planning to report you at all because it only happened once, it might have been a mistake so I let it slide, but when you repeated the same thing over and over again I knew that there was something wrong and you don't know the rules of the Hydra. You don't deserve to be in this team, you are a liar and a rulebreaker who doesn't want to admit his mistakes, in the second clip we had no highly wanted suspects on the roof, only me and Koko were oranges teaming up with WareHit(MW), how did you not see us when your hydra was literally 0.00001 miles away from us? you were very close and you could have seen our name tags with the colors of it, also you could check the player list by pressing on your TAB button.Spoiler: show
Cover wrote:I confirm what Cover said in his report, he didn't plan to report him, i told him to do it.LikeWise wrote:Yes, I said "no worries" because I wasn't even planning to report you at all because it only happened once, it might have been a mistake so I let it slide, but when you repeated the same thing over and over again I knew that there was something wrong and you don't know the rules of the Hydra. You don't deserve to be in this team, you are a liar and a rulebreaker who doesn't want to admit his mistakes, in the second clip we had no highly wanted suspects on the roof, only me and Koko were oranges teaming up with WareHit(MW), how did you not see us when your hydra was literally 0.00001 miles away from us? you were very close and you could have seen our name tags with the colors of it, also you could check the player list by pressing on your TAB button.Spoiler: show
EDIT: You said that you know the Army rules and it was only a mistake because you "couldn't see the oranges on your map" then why did you tell Faraon when WareHit teleported you to the Admin HQ that you are allowed to attack oranges who are teaming with most wanted, it was a simple question but you failed to answer it, instead of admitting your mistakes you insisted that you were right but the rules says otherwise.
