Hooligans Suggestions : DRA.gon
If you would like to share any good ideas in your mind, you may go here and announce it
Dragon.
[Lsrcr]Dragon
Post by Dragon. » May 6, 2024, 2:07 pm
Your name: DRA.gon
Suggestion: Shape Votes
Why would we accept: I see a little Did this but I see it good to group all same shape vote this It increases the strength, shape and structure of the group
Reason: I think it is the best shape, and it will be a wonderful shape, and it will be distinct from the rest of the others, and I hope you like it.
Anything else:
Example.
My Vote PositiveImage
Reason 1
Reason 2
Reason 3
Good luck with your application
My Vote NeutralImage
Reason 1
Reason 2
Reason 3
My Vote NegativeImage
Reason 1
Reason 2
Reason 3
This Vote Positive
Code: Select all
[center][legendary=green,White,My Vote Positive][url=https://ibb.co/17HZV9F][img]https://i.ibb.co/9cRnXqQ/Picsart-24-05-06-16-35-06-432.png[/img][/url]
[hr][/hr]
[b]Reason 1[/b]
[b]Reason 2[/b]
[b]Reason 3[/b]
[b][color=#008000]Good luck with your application[/color][/b][/legendary][/center]
This Vote Neutral
Code: Select all
[center][legendary=yellow,white,My Vote Neutral][url=https://ibb.co/mvNszw7][img]https://i.ibb.co/LQNwpWf/Picsart-24-05-06-16-43-27-694.png[/img][/url][hr][/hr]
[b] Reason 1[/b]
[b] Reason 2[/b]
[b] Reason 3[/b]
[b][color=#FFFF00] Good luck with your application[/color][/b]
This Vote Negative
Code: Select all
[center][legendary=red,White,My Vote Negative]
[url=https://ibb.co/JKX145B][img]https://i.ibb.co/rmnjS47/Picsart-24-05-06-16-35-27-001.png[/img][/url]
[hr][/hr]
[b] Reason 1[/b]
[b] Reason 2[/b]
[b] Reason 3[/b]
[b] [color=#FF0000]Good luck with your application[/color][/b]
Post by Commander » May 20, 2024, 11:27 pm
Sorry for being late, I don't have any troubles with this so hooligans may use it if would to
Locked
Return to “Suggestions”
