Where does the bug appear: Server
When did the bug appear: Quite a long time now
Describe the bug:
You supposed to get cash from something like money bags, collectibles(briefcase) ,/gc or claiming a hit . Each of example that I gave had this issue happened to me, delivering money bag the cash goes up then instantly back to the original cash that I had when delivering the money bag. Collectible's case is in the video above. If you're /gc to someone for a huge amount of cash that needs you to do it for like 10+ times constantly, you're most likely will have a short of $5000 from the original amount which means the bug is triggered. This bug will also happens if you're claiming a hit, will be annoying if it's a huge amount of hit placed.
Frequency: Once in a while
Severity: major
I have some solutions in mind, but I need someone that has this problem frequently. If you're able to easily recreate this or at least have a high chance of recreating it please send me a message on discord.
I have just tested this with the /gc command with Ritz (average 250 ping). It's apparently a bad internet/high ping issue, which normally means the anti-cheat is too fast. I have managed to add a failsafe so that when the money is about to get deducted again, it verifies the money again before doing anything.
This fix will be added in the next version marked as BETA. Keep in mind, this bug is in a very sensitive part of the server. If you get too much money, or your money gets deducted more than normal, please reply here so that I can handle it before it gets out of hand.
Big thanks to Ritz for helping me out in his free time to test for this bug
I will keep the topic open if someone has found a problem with this (in the next version).
