October 20, 2024, 4:31 amRichano wrote: Could you elaborate some more? I don't really know if you mean losing a wanted level or some feature which removes your wanted level.Pagati has a desk where we can press F, enter an ID, and remove a wanted level. Last patch it was given an area of effect where we cannot remove a wanted level with police nearby, but it's WAY bigger than it should be
October 20, 2024, 10:18 amHiresh wrote: Hello, I've tested it on beta multiple times and on the locations you mentioned aswell, but the range check was working as expected. Could you make a screenshot of your map the next time this is happening, and by any chance do you know if the officers were afk?Will grab you the map screenshots next time I have it happen, and no, I mean SWAT base. It is located on the other side of the hill from Pagati, across the riven from Easter Bay Airport
Also, san fierro SWAT base? Do you mean the police station?
October 20, 2024, 11:19 amKaru_Tepes wrote:There's no SF SWAT base, atleast not an official one with a SWAT zone.October 20, 2024, 10:18 amHiresh wrote: Hello, I've tested it on beta multiple times and on the locations you mentioned aswell, but the range check was working as expected. Could you make a screenshot of your map the next time this is happening, and by any chance do you know if the officers were afk?Will grab you the map screenshots next time I have it happen, and no, I mean SWAT base. It is located on the other side of the hill from Pagati, across the riven from Easter Bay Airport
