Name doesnt shows up in /gl when spawning in LEO groups as SWAT/Army
Ritz
[Lsrcr]Ritz
Post by Ritz » October 27, 2024, 6:56 am
Where does the bug appear: server
When did the bug appear: After new version released maybe
Describe the bug: Referring to Storm, his name were supposed to shown in /gl while spawning as SWAT if he /gspawn in LSPDU , but I asked him to do it yesterday his name is not showing up. Same thing happened to me , I spawned as Army and /gspawn in Spetsnaz , but /gl doesnt shows up.
Frequency: always
Severity: minor
Steps to reproduce: /gspawn LSPDU/Spetsnaz then spawn SWAT/Army
Post by Astrl » October 30, 2024, 10:33 pm
Hey Ritz, thanks for reporting this - I've just been through the code and the code history, this has remained the same since at least January 2020 so doesn't look like it's been recently introduced! Might have just slipped through the net :D
What I have discovered, is that when you set the group you want to spawn at, it's not cleared when you fail to spawn (so you technically still have access to everything such as /gm etc.) - this is not the intention and is the actual bug here.
I've cleared the group spawns now when these conditions are met, where it actually tells you that you can't spawn as a certain class / faction / area, it'll save your stats and disable the group spawn (just like it does when you cancel spawning).
Thanks for reporting - should be on main when the server next restarts!
