Moderator: Renegades Managers
iTsYost - Thank you for applying for Renegades
Before we can accept or deny you, you must pass our test that consists of two parts:
-Knowledge of Renegades & Server rules
-interview part
You will be asked a minimum of 10 questions, and you are allowed to answer 1 question incorrectly. And then you will be given a task to achieve if you finished it within the given time you will automatically get 10/20 upon achieving the task at hand. The other 10 will be according to your performances.
The maximum time period to get tested is 7 days since you post your application or else it will be auto-denied unless you ask us to extend it due to a valid reason.
You may get tested by any one of the following Recruiters:
Thorax ⚚
Boyabunda ⚚
If the recruiters aren't able to take your test, you may also request to get tested by the Head Training Officer:
Alessandro
Kindly do not annoy or spam a tester to take your test if they aren't free, it may lead to the denial of your application. Do keep in mind that every tester has different methods of testing applicants.
Good luck with your test!
