S.A. Army [★] Suggestion: Add a rule along with a new cmnd that players are required to comply with.
Have you got something in mind that you'd like to suggest for S.A. Army? Post your suggestions & improvements for S.A. Army here.
Wazuki
[Lsrcr]W4zuki
Post by Wazuki » December 27, 2025, 9:19 pm
Suggestion(s): Solution for a situation where soldiers can't open fire when innocent players nearby wanted suspects under vehicle's rules.
Why would it be useful: Adding a rule along with a cmnd against innocent players who are teaming with wanted suspects, whether the innocent player is actively doing a job or is being used by wanted suspects standing nearby to prevent soldiers from opening fire under the rules, would definitely be the best option. I can see how soldiers suffer when they have to repeatedly ask an innocent player to get wanted, sometimes a thousand times. With this rule, the soldier would ask only once, if the player doesn’t comply within a few seconds, the soldier may then directly open fire.
This is about justice, where both civilians and soldiers are held to the same standard, and no one escapes justice. Also, This could help handle situations where players avoid direct fair duels or This could help soldiers who aren’t able to hold their ground in a proper duels.
Additional comments: AHC should no longer jail an innocent player if they fail to comply after a single request. Furthermore, innocent players can be abused by wanted suspects standing nearby to prevent soldiers from opening fire under the rules, especially when the innocent player is AFK. In such cases, there should be a possibility to put the AFK innocent player in admin jail. This directly addresses the injustice that occurred a few days ago.
If this suggestion is dismissed, then it becomes AHC’s responsibility to acknowledge the ongoing injustice toward wanted suspects.
Note: I hope this suggestion will not be deleted by AHC, as happened previously on the Discord channel due to disagreement or dislike with the wording rather than the content.
Mockery
[Lsrcr]Mockery
Post by Mockery » December 28, 2025, 3:40 pm
We do not intend on adding any such command, however you can expect a rule change in the upcoming promotions. The AHC team is currently discussing the rule update, and after consultation with seniors the updates will be announced soon (hopefully in the upcoming promotions topic).
Return to “S.A. Army [★] Suggestions”
