[Lsrcr]ThoraX c bugging
7 posts Page 1 of 1
Knavery
[Lsrcr]Knavery
Post by Knavery » June 17, 2026, 9:10 am
Your name : [Lsrcr]Knavery
Their name : [Lsrcr]ThoraX
Reason : c-bugging
Proof : https://streamable.com/2apgop
anything else : you are not new in our server and i expect you know the rules since you were tagged member. You should be careful to your action since you are Community Representative..
ThoraX
[Lsrcr]ThoraX
SWAT VIP Blackmarket VIP
Post by ThoraX » June 17, 2026, 11:38 am
that's not a c-bug brother, most players play like that and rry to learn the technique, it's most likely just fast switching, but not fast enough to completely skip the animation.
even admins use that sniper playstyle. it's obviously not a c-bug. I've done the same thing before against numerous experienced players like Connie and iFace. they initially thought it was a c-bug too, but after I explained it to them, they realized it wasn't and even wanted to learn the playstyle themselves.
Knavery
[Lsrcr]Knavery
Post by Knavery » June 17, 2026, 12:22 pm
I'm not so good to look wether its a c bug or not but i'm pretty sure it was clearly C-bug.
Hey brother, before i make a report i sent the clip to luka to review it. If you meant not a c bug then luka is lying ? https://imgur.com/a/xMwhkNo
Don't make it personal bro. I'm just doing whats the rule is. Rule is rule . Breaking the rules will gain a consequence and u need to accept it.
ThoraX
[Lsrcr]ThoraX
Post by ThoraX » June 17, 2026, 12:25 pm
if you focus well, make the video on slow motion, you will just realize that I DIDN'T PRESS C. because if I really pressed C, I wouldn't take that moment to switch, but you can clearly see that I took a moment to switch, I didn't skip it. I even used that playstyle against admins and it's normal wdym
if you want I can send a clip with the clear playstyle.
Knavery
[Lsrcr]Knavery
Post by Knavery » June 17, 2026, 1:19 pm
Nothing much to say bro, lets wait staff to decide on it.
ThoraX
[Lsrcr]ThoraX
Post by ThoraX » June 17, 2026, 2:07 pm
here is clip of how it works:
https://streamable.com/wfj5fh
but this is faster a bit compared to how I switched in Knavery's clip.
you can clearly see the keyboard, the C key never pressed.
Luka
[Lsrcr]Luka
Post by Luka » June 18, 2026, 8:45 am
I've watched multiple videos on YouTube where people showcase similar "technique", but they all use the crouch key at some point in their example.
After consulting multiple staff members, it was decided that this may or may not be C-bug. I have personally never seen this type of movement being done without using the crouch key, but then again I've been away for 6 years and much has changed.
Thorax, in case you did use crouch key to cancel the animation, do consider this as a warning to not do it again.
Appreciate the report.
7 posts Page 1 of 1
