Report - [Lsrcr]Bobbi
Awdallah
Awdallah
Post by Awdallah » June 23, 2026, 12:26 am
Your name: Crusheer
Their name: [Lsrcr]Bobbi
Reason: using animation command "/lean 1" while in combat
Proof: https://streamable.com/yqrskj
Anything else: really i dont like to be a report hunting but he's a tagged member and rules are rules, also he lied on me when i asked him what happened he responded by. "someone rammed me"
Bobbi
Bobbi
Post by Bobbi » June 23, 2026, 12:42 am
Hi everyone,
Firstly, you weren't present at the time. I even whispered to Yost to use Lean 1. No criminal was surrounded, and our helicopter got glitched, which is why I did that to avoid losing health.
You arrived later and only saw the situation from a different point of view. If I had been aware that anyone was around, I would not have used lean in that way.
Also, before reporting an experienced player, please try asking them about the situation first, especially since many of you regularly message me for different things. I usually joke around and have fun with everyone rather than giving direct or serious responses all the time, so misunderstandings can happen.
I would also like to request that the admins please check the chat logs to confirm my conversation. I informed a tagged member about this beforehand through whispers.
The rest is up to the admins, but I kindly ask that the chat logs be reviewed, as they will confirm that I informed someone about the situation before it happened.
Best Regards,
Awdallah
Awdallah
Post by Awdallah » June 23, 2026, 12:49 am
June 23, 2026, 12:42 amBobbi wrote:
Hi everyone,
Best Regards.
man i were fighting "Yost" and u didnt cancel the command, first of all u lied on me, also if u didnt u wasnt see ur name around the reports section...
anyways, its the right call our staff.
note: can u say when u used this command and why u used this command on our vla roof and you know we were fighting in this time and u one of them was fighting us, i can mentioned the friends were playing with me, anyways, if iam not sure from that report i wont do it bro... also if u wanna cancel this command u will use another one to be removed so do not lie here also please. also we no need any of chat alogs because everything too clear in my pov
Cover
Post by Cover » June 23, 2026, 2:50 pm
Bobbi, you clearly should not be using this bug, regardless of whether other players are nearby, as it creates an unfair advantage. This is nearly as serious as using a speed hack to boost yourself.
Instead of exploiting it, you should have reported it to the Developers so that a fix could be implemented.
Therefore, we have unfortunately decided to remove your tag and verbally warn you. Please refrain from using this bug or encouraging others to use it until it has been fixed by the Development Team.
Your name has been reverted to: Bobbi
Thanks for reporting!
Users browsing this forum: ABo3ZaT, Daemon, Karu_Tepes, Milyn, Swaka and 3 guests
